fuel? help fast please!
Old Oct 26, 2003 | 08:14 AM
Scharged2000GsR's Avatar
Default fuel? help fast please!
i just installed a jrsc on my 00 gsr. i was going to get rc racing injector 310. then i was told to get 440. so i started to call around to place acking what the prices were for those. but then i called a-pexs motorsports and they said that jrsc was made to be able to run with stock injectors! so as of right now thats want im running. is that TRUE? my car is not running cuz i have not set the timeing but i plan on doing that 10-26. some one all so said that i need to remap my fuel ****. and that i need some kind of cip. i real dont know what he was talking about. so help me if you can!
Old Oct 26, 2003 | 09:09 AM
IN VTEC's Avatar
Default Re: fuel? help fast please! (Scharged2000GsR)
The JRSC was designed to use stock 240cc injectors in conjunction with a boost-dependent rising-rate fuel pressure regulator (aka FMU - Fuel Management Unit) and a higher volume/pressure fuel pump.
You won't need to use it with larger injectors, but you will need either an AFC, a "standalone" like Hondata or something more like an EMS, Tec3, Microtek, Motec, etc. That way you can trim down the larger injectors where you don't all that fuel. Some units have other functions and options that you may or may not want or need...you just need to weigh the cost-benefits.
Get the 440cc's. More room for growth and they're not that much more if you buy them new. The 310cc's are easier to find used b/c people underestimate their fuel needs and max them out pretty quickly.
There's quite a bit more to it than that, but that'll get you started.
Old Oct 26, 2003 | 04:40 PM
Muckman's Avatar
Moderator in Chief
Of course you can use it with stock injectors. The JRSC kit comes with everything you need to get you running. If you needed bigger injectors it would have come with them or tell you to get them.
Did'nt you research this before you bought it?
oacrep1
Feb 6, 2006 07:34 AM
hondaeg8
Jul 7, 2005 11:01 PM
DeDonDeRosa
Dec 16, 2002 11:19 AM
grand600
Sep 27, 2001 09:58 PM
ndmracing
Aug 30, 2001 01:57 PM
