JRSC on gsr.. how do you get...
8psi?
i have the stock 6psi pulley, but i want to run 8psi.
is there a different pulley i can buy to get to 8psi?
easy,put a CR-V crank pulley on your car and it will raise it to 8psi.if you change out the blower pulley,you have to take out the blower or atleast take it loose,and move it up because you will not be able to take off the pulley with it in your car.so the crank pulley is alot easier.
