where to get 10 psi pulley for JRSC GSR
Re: where to get 10 psi pulley for JRSC GSR (B18Cwon)
Re: where to get 10 psi pulley for JRSC GSR (RacerXI)
i was trying to find a pulley that was made for 10lbs. i know that the crv and ls crank ones will work but i have heard that they are not made to spin that fast and cause other things to wear prematurely.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18Cwon »</TD></TR><TR><TD CLASS="quote">i know that the crv and ls crank ones will work but i have heard that they are not made to spin that fast and cause other things to wear prematurely. </TD></TR></TABLE>
A lot of guys use the crv pulley. I've never heard of that problem, but I can't say for sure. I used a MVM stepper pulley, but it only gets me to 8 psi on my ITR. I think it is a little higher on the gsr. Stay away from smaller blower pullies. Since they have less surface area the belt is more likely to slip.
Re: where to get 10 psi pulley for JRSC GSR (fredtoast)
I have run CRV and LS pulley on so many cars I can't keep track of. If you run at 8000rpms all the time with the A/C on you may have compressor problems, Other than that you will be fine. As for the small blower pulleys, you will have belt slippage problems.
LS crank, Endyn stepper pulley and a 4.2" = 10 psi on a GSR,
LS crank, endyn steper pulley and 4.0" = 11-11.5 psi on GSR.
