JB vs. Tig Weld vs. Rubber washers
JB vs. Tig Weld vs. Rubber washers oil return poll
hey guys im finishing up my turbo project EJ coupe and i was wondering if i should JB weld it tig weld it or just use a nut on the inside with rubber washers and some hondabond. . . *EDIT* on my oil return!! sorry about that!
Modified by IWantATurbo at 9:14 AM 4/16/2006
Re: JB vs. Tig Weld vs. Rubber washers oil return poll (IWantATurbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IWantATurbo »</TD></TR><TR><TD CLASS="quote">hey guys im finishing up my turbo project EJ coupe and i was wondering if i should JB weld it tig weld it or just use a nut on the inside with rubber washers and some hondabond. . . *EDIT* on my oil return!! sorry about that!
Modified by IWantATurbo at 9:14 AM 4/16/2006</TD></TR></TABLE>
lol, D all of the above
JK, do you have a tig welder? If so Id use that. I know i do that to mine
i tapped my pan with a brass barbed fitting and sealed it with JB weld..........holding up just fine......no leaks
if you have access to a welder then do it that way.......if not then be creative.
Re: JB vs. Tig Weld vs. Rubber washers oil return poll (aallbbeerrtttttt)
i used jb weld for about 2 minutes....then it started leaking....maybe i just suck with jb but, i'd weld it if you can.
Re: JB vs. Tig Weld vs. Rubber washers oil return poll (non-VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by non-VTEC »</TD></TR><TR><TD CLASS="quote">i tapped my pan with a brass barbed fitting and sealed it with JB weld..........holding up just fine......no leaks
if you have access to a welder then do it that way.......if not then be creative.</TD></TR></TABLE>
exactly how i did mine...and all of my friends cars....a 3/4" tap & drill bit were a lil pricey.....you can get 1 or 2 good threads on the fitting and i used epoxy puddy around the edge of the fitting to add a lil reinforment and leak proofin...been workin great...no a dam drop of oil
1 Post
Re: JB vs. Tig Weld vs. Rubber washers oil return poll (N20civicB18)
I have known people that have used alot of JB weld and it worked without leaks but its a little to ghetto for me.
I used a fitting with a nut and copper crush washers coupled with teflon tape and copper spray gasket maker .... it leaks
Next oil change I am pulling the pan and welding it in. Welding is the obvious best choice in this scenario so even if you have to pay somebody $10 to weld it, thats so cheap there is really no reason to not do it right the first time and save yourself a future head ache.
