ITB's with FI
Old Sep 28, 2004 | 04:13 PM
  #76
Tony the Tiger's Avatar
Default Re: (MidShipCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MidShipCivic &raquo;</TD></TR><TR><TD CLASS="quote">The turbo charger is not a throttle plate its always sucks in the air the rule applys to boosted motors I'm assured now.
You don't understand... how is the turbo ever going to suck air if the engine doesn't produce exhaust? You see, before the turbo can suck and push air into the engine, the throttleplate has to be opened first so the turbo can spool.
The air resonance rule always apply to boosted motors... But the discussion was about whether it applies to boost AND ITB's. By looking at the above concept, the rule does indeed apply to boost and ITB's.
It was Fullrace Geoff who mentioned that this rule does not apply to ITB's and boost... But I am not convinced though.
Old Sep 28, 2004 | 04:37 PM
  #77
Archidictus's Avatar
Unceasing Measure
Default Re: (Tony the Tiger)
I'm not an engineer, nor would I ever suggest otherwise. This question is about curiosity and not my attempt at problem solving, i.e. I just want an answer from anyone who might have a clue.
Could you potentially solve the plenum problem (with ITB forced induction) by running basically the opposite of a merge collector into the individual throttle bodies? I mean, maybe run the charge air through a water-to-air cooler and then into a "medusa" style manifold that would pipe charge air to each ITB rather than to a dedicated plenum where the air charge would be scavanged as needed.
Just curious. You'd get a **** ton of top end this way, although I'm willing to bet you'd be lacking a lil torque in the bottom.
Old Sep 29, 2004 | 12:10 PM
  #78
Boostage's Avatar
Default Re: (Archidictus)
bump for his question
ls_bitik
Mar 6, 2008 07:48 AM
idriveadelsol7
May 15, 2005 07:09 PM
B20luda
Nov 13, 2004 05:03 AM
stRodda
Aug 30, 2004 08:18 PM
