instantly warm??
Old Jul 23, 2005 | 07:59 PM
  #26
Slavko's Avatar
Default Re: (suxway)
1.Check if your thermostat is opening. It could be stuck closed.
2.Bleed the system
3. Check if water pump is working.
Old Jul 23, 2005 | 08:02 PM
  #27
budget's Avatar
Default Re: (Slavko)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slavko &raquo;</TD></TR><TR><TD CLASS="quote">1.Check if your thermostat is opening. It could be stuck closed.
2.Bleed the system
3. Check if water pump is working.</TD></TR></TABLE>
99% sure the thermostat is opening b/c the bottom rad. hose gets hot and i was told it would overheat alot more if it was stuck closed.
bled the system twice
how do i check the water pump
Old Jul 23, 2005 | 08:59 PM
  #28
Slavko's Avatar
To check if your water pump works, Run the car with cap off until the thermostat opens. Keep looking inside the radiator until you see the water circulating. If the water never looks like its flowing/circulating, then that water pump doesn't work.
Old Jul 26, 2005 | 12:12 PM
  #29
budget's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slavko &raquo;</TD></TR><TR><TD CLASS="quote">To check if your water pump works, Run the car with cap off until the thermostat opens. Keep looking inside the radiator until you see the water circulating. If the water never looks like its flowing/circulating, then that water pump doesn't work.</TD></TR></TABLE>
it works
732xghost
Aug 26, 2009 07:20 AM
ge_itr
Dec 2, 2006 07:29 AM
flood
Dec 5, 2005 06:21 PM
tianporn
Jun 18, 2005 07:22 PM
PreIudeSI
Aug 24, 2004 09:55 PM
