heating problem
Old Nov 30, 2006 | 09:09 AM
ge_itr's Avatar
Default heating problem
just took my car out of storage and notice there were no heat after drinving it for 30 minutes. what could be the problem?
Old Nov 30, 2006 | 11:07 AM
Lan's Avatar
Lan
Default Re: heating problem (ge_itr)
Fuse, or something wrong with your cooling system. Do you have any leaks? Does the fan blow?
Old Nov 30, 2006 | 12:18 PM
GRAF-FITI's Avatar
* B A N N E D *
Default Re: heating problem (Lan)
thermostat could be stuck open
Old Nov 30, 2006 | 02:57 PM
ge_itr's Avatar
cooling system and fan seems to look fine. what fuse should i check.
Old Nov 30, 2006 | 03:00 PM
yee SERIOUS's Avatar
low coolant? clogged heater core?
Old Nov 30, 2006 | 03:35 PM
ge_itr's Avatar
could it be the thermostat?
Old Nov 30, 2006 | 03:37 PM
Lan's Avatar
Lan
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ge_itr &raquo;</TD></TR><TR><TD CLASS="quote">could it be the thermostat?</TD></TR></TABLE>
Does it take forever for your car to warm up?
Old Nov 30, 2006 | 04:12 PM
ge_itr's Avatar
no, it just blow out could air. im talking after driving for long long time. 2 hrs drive and still blows out cold air.
Old Nov 30, 2006 | 04:18 PM
agrn93ls's Avatar
if your gauge is also reading cold put a thermostat in if your gauge is normal and the air is cold check for plugged heater core or blend door
Old Nov 30, 2006 | 10:54 PM
99Geeezer's Avatar
Is the temp guage working properly? ifso maybe the thermostat.
Old Nov 30, 2006 | 11:37 PM
BLKGSR24's Avatar
air in the cooling system. One time my heater wasn't blowing hot air so someone advised me to bleed the system, and sure enough once I did that it was hot again.
Old Dec 1, 2006 | 05:24 AM
ge_itr's Avatar
Default Re: (BLKGSR24)
my temperture gauge is fine. i think theres air in the cooling system because my upper radiator hose is always tight (pressure inside) and first time when i open the radiator cap when car was still cool anti freeze would overfilled. but could it still be the thermostat.
Old Dec 1, 2006 | 05:26 AM
ge_itr's Avatar
how do i bleed the cooling system?
Old Dec 1, 2006 | 09:55 AM
ge_itr's Avatar
Default Re: (ge_itr)
finally figure what was the problem. took my car to midas and they told me there were no cable attached to my cool and warm control (climate control). they said they manually put it on warm for me. can anybody tell me how they did that. they want $97 to fix it. do have to take the climate control unit to fix this problem?
Old Dec 1, 2006 | 11:17 AM
on the back of your climate control is a cable. (it's item 12 in this picture)
it moves a door on the heater box under the dash so that coolant can flow through to make heat. it looks like it's replacable since they sell the part by itself. on my old car the cable just came off from the box, so i just put it back on.
Old Dec 1, 2006 | 11:23 AM
ge_itr's Avatar
Default Re: (undercoverdc2)
how to i get the that cable?
Old Dec 1, 2006 | 12:37 PM
huh? what did you say? lol how do you get that cable? or how do you get to that cable?
Old Dec 1, 2006 | 01:33 PM
Blk-dc2's Avatar
were did you get that pic at, all data, what program is it from????
Old Dec 1, 2006 | 01:43 PM
ge_itr's Avatar
how do i get to that cable? what do i have to open up.
Old Dec 1, 2006 | 01:54 PM
99b18c's Avatar
What is your car? integra?
Old Dec 1, 2006 | 01:57 PM
99b18c's Avatar
it is generaly the ball valve in the heater hose going through the fire wall. You can see it down low behind you engin. the cable is prone to coming off, especialy if you live in the rust belt
Old Dec 1, 2006 | 02:00 PM
ge_itr's Avatar
Default Re: heating problem (99b18c)
i just check. on part 12 everting seems to be alright. i think the problem is on parts 18 10 or 11. i'll have to take out my cd player or whatever i need to have a look at that.
Old Dec 1, 2006 | 03:03 PM
Default Re: (BLACK-dc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLACK-dc2 &raquo;</TD></TR><TR><TD CLASS="quote">were did you get that pic at, all data, what program is it from????</TD></TR></TABLE>
i imagine it and it comes true!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ge_itr &raquo;</TD></TR><TR><TD CLASS="quote">i just check. on part 12 everting seems to be alright. i think the problem is on parts 18 10 or 11. i'll have to take out my cd player or whatever i need to have a look at that.</TD></TR></TABLE>
ok, get under your dash, and look to see where that cable connects to the heater box. i didnt drive my integra today, so i don't know which box it's connected too. lol but i think it's the one on the left shown below. the one on the right is the a/c box i believe.
but it should be one of those two. slide the temperture thing on the climate control back and forth and the cable should retract in and out pushing a lever on one of the box. if the cable does not retract, you need to replace the cable or something is wrong behind your climate control where the cable is connected.
Old Dec 2, 2006 | 04:44 AM
ge_itr's Avatar
yep. its something inside. how do i take of climate control? never did that before.
Old Dec 2, 2006 | 07:29 AM
you gotta take apart the center console, and then take off the ashtray, lighter, deck, etc. it takes a while......
clownsaw
Mar 3, 2011 11:13 PM
732xghost
Aug 26, 2009 07:20 AM
flood
Dec 5, 2005 06:21 PM
tianporn
Jun 18, 2005 07:22 PM
Calavera
Jan 23, 2004 06:53 AM
