Boost Controller...Which is better for the cost?
Old May 28, 2008 | 02:58 PM
LSej1's Avatar
Default Boost Controller...Which is better for the cost?
I'm Looking for a boost controller and at first a was going to buy the APEXi Electronics - AVC-R Boost Controller but then a friend told me to get a GReddy profec B spec II. what one is more player friendly and better for the money
(apexi = $447.81)
(greddy = $302.40)
Old May 28, 2008 | 03:46 PM
lilintegra25's Avatar
i have greddy,, and its awesome.... you can adjust from low to high boost in about 2 seconds
Old May 28, 2008 | 07:20 PM
inspyral's Avatar
I'm running a BLITZ SSBC with dual presets. It's simple, easy to use, and has worked very well for me. I don't know if they still make them, but it was around $200 when I got it back in like '00-'01. What EMS are you running? If you're running Hondata S300 or any other EMS that supports integrated boost control, your best bet would be to pick up a boost control solenoid and make use of it. You can even set up the boost by gear for improved traction. The AVC-R also has a speed-based boost control function, but it's pretty pricey.
Old May 28, 2008 | 07:37 PM
HamiltonRex's Avatar
Default Re: (inspyral)
you can find the apexi unit much cheaper.. I am using it personally. Car gets tuned saturday.
Old May 28, 2008 | 08:00 PM
hybridsol's Avatar
Default Re: Boost Controller...Which is better for the cost? (LSej1)
Ive used the Greddy unit, works and is fairly easy- has small buttons. I'm runnning and Turbosmart unit, works very well (boost control) and has some very nice features you can actually use (like different settings, day/night light, etc.) I forget how much it costs though...
The boost solenoid has held up very well... it's better IMO than the Greddy unit with the filters.
Old May 28, 2008 | 09:40 PM
lsvtechatch92's Avatar
neither... use boost control throught the ecu and a solenoid its cheaper too
Old May 28, 2008 | 11:15 PM
HiProfile's Avatar
You know we have it easy when you can buy an EMS that comes with boost control for less than a standalone EBC. Some of them do allow a high/low setting too via a potentiometer input IIRC. Anyways I've heard the Greddy unit has a good balance between programability and funtionality, and is cheaper too.
Old May 29, 2008 | 04:13 AM
LSej1's Avatar
Default Re: Boost Controller...Which is better for the cost? (HiProfile)
I am buying an ECU through http://www.phearable.net/ just going with the basemap OBDI. I dont know where i am going to get it tuned yet because there isnt a tuner within a 3 hour radius of where i live...SOOOO im not sure what to do
Old May 29, 2008 | 06:23 AM
morgan@synapse motorsport's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSej1 &raquo;</TD></TR><TR><TD CLASS="quote">I am buying an ECU through http://www.phearable.net/ just going with the basemap OBDI. I dont know where i am going to get it tuned yet because there isnt a tuner within a 3 hour radius of where i live...SOOOO im not sure what to do</TD></TR></TABLE>
We're only 2 hours away if you're interested.
you can run an electronic solenoid on neptune, neptune rtp, or hondata s300.
Old May 29, 2008 | 10:40 AM
SpoolnG2's Avatar
Default Re: (lsvtechatch92)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lsvtechatch92 &raquo;</TD></TR><TR><TD CLASS="quote">neither... use boost control throught the ecu and a solenoid its cheaper too </TD></TR></TABLE>
and you can use boost by gear
Old Jun 3, 2008 | 03:49 AM
LSej1's Avatar
Default Re: (SpoolnG2)
I think i might go this route im not sure...Depends on where i get my car tuned...
Old Jun 3, 2008 | 08:21 AM
boostedcivicsir's Avatar
Mr. Badwrench
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HiProfile &raquo;</TD></TR><TR><TD CLASS="quote">You know we have it easy when you can buy an EMS that comes with boost control for less than a standalone EBC. Some of them do allow a high/low setting too via a potentiometer input IIRC. Anyways I've heard the Greddy unit has a good balance between programability and funtionality, and is cheaper too.</TD></TR></TABLE>
ding ding.
i had a blitz dual sbc. it was nice but taming 27 psi out of the hole wasnt fun he hee.
Old Jun 3, 2008 | 08:36 AM
94delslo's Avatar
Old Jun 3, 2008 | 09:41 AM
SPOOLINmatt's Avatar
Default Re: (94delslo)
for a street boost controller
Greddy Spec B II Electronic boost controller is my favorite.
RACEPAK
Apr 25, 2007 05:18 PM
hovic
Mar 16, 2005 01:19 PM
FlatTire
Sep 8, 2004 09:39 PM
PrecisionH23a
Jun 9, 2002 10:37 PM
DIRep972
Aug 5, 2001 07:51 PM
