Drag 3 install....
Old Oct 9, 2001 | 01:12 PM
CM-R's Avatar
Default Drag 3 install....
Is the drag 3 install hard to do or does it just take a while to do?.....any type of fabrication involved??
Old Oct 9, 2001 | 01:21 PM
b18bturbo's Avatar
Default Re: Drag 3 install.... (CM-R)
takes approx 6hrs if you know what you doing. Takes approx 14hrs if you have a good idea of what you are doing. takes approx 24hrs if you want to take your time.
Old Oct 9, 2001 | 02:34 PM
Damon B.'s Avatar
Default Re: Drag 3 install.... (b18bturbo)
That's good to know. I'm just gonna set aside a weekend, just to give my self plenty of room.
Old Oct 9, 2001 | 03:05 PM
chri5's Avatar
Default Re: Drag 3 install.... (CleanSi)
im at about 9 hours now and we're getting pretty close. That is without only haveing a slight idea of what I'm doing. 14 sounds about right for me. and that includes sevral trips up to the store. My new Dremel kicks ***!
Old Oct 9, 2001 | 10:53 PM
CM-R's Avatar
Default Re: Drag 3 install.... (Chris_Turbo)
Why do you need a dremel for?...i do have a dremel if i need it.....and why does it take so long to put on the drag kit?
[Modified by CM-R, 11:54 PM 10/9/2001]
Old Oct 10, 2001 | 12:18 AM
b18bvudoo's Avatar
New User
I believe you need the dremel to cut the fan housing to fit the turbo, pretty easy i guess.
Old Oct 10, 2001 | 12:52 AM
B18C-EJ1
Guest
Posts: n/a
Default Re: Drag 3 install.... (vudoo666)
Don't forget to notch the block, and you'll have to get the downpipe welded to fit your exhaust on.
Plan on it taking a while.
Old Oct 10, 2001 | 04:50 AM
maxim's Avatar
Default Re: Drag 3 install.... (B18C-EJ1)
you might not have to trim the fan depending on what you have. Civic - no, Integra - yes. What is this kit going on?
Old Oct 10, 2001 | 10:49 AM
CM-R's Avatar
Default Re: Drag 3 install.... (maxim_force)
Its going on an 2000 integra GSR...is there any instructions for all of this that come with the kit??....because i dont want to make a mistake....
Old Oct 10, 2001 | 11:03 AM
MackSpeed-616's Avatar
lol.. no there are no instructions that come with the kit
Old Oct 10, 2001 | 11:26 AM
DirtyLude's Avatar
Default Re: Drag 3 install.... (TurboR616)
http://www.importparts.com has an installation manual. No pictures or anything but it's fairly good. Go to http://www.importparts.com click on Customer Service and the Drag 3 installation manual is near the bottom of the list.
Old Oct 10, 2001 | 11:29 AM
adam's Avatar
Anyone ever heard of the fan melting? Just curious, it sits pretty close to the turbo which gets quite warm
Old Oct 10, 2001 | 11:30 AM
CM-R's Avatar
Default Re: Drag 3 install.... (DirtyLude)
damn that sucks no instructions....i'll go check out importparts.com thanks for info....
Old Oct 10, 2001 | 11:53 AM
Ben Huynh's Avatar
Default Re: Drag 3 install.... (adam)
No the fan won't melt.
JDM_EH2
Jun 20, 2003 06:41 AM
geminis2k
Oct 17, 2002 07:46 AM
vteckiller
Jul 21, 2002 07:25 AM
R-1303
Feb 12, 2002 03:32 PM
T.Werd
Nov 11, 2001 08:27 PM
