Need Help Please. Turbo Install Problems...
Old Jun 30, 2003 | 07:57 PM
turbo2000's Avatar
Default Need Help Please. Turbo Install Problems...
I just started on my turbo install two days ago and I've been running into a lot of little problems... the usual block trimming and cutting the fan to get everything to fit. I have a drag manifold and the fitment is really tight especially with the bolt in the center of the manifold. I couldn't get the stock bolt to fit so I had to get a stud. The problem I'm having now is getting the dipstick to go in. I've tried trimming the rubber part but it still won't go through because the stud is blocking the way. How do you guys with the drag kit get the dipstick in? I'm sure I have more problems too but i'm stuck on getting this one fixed right now... any help would be appreciated. thanks
Old Jun 30, 2003 | 09:15 PM
turbo2000's Avatar
bump because i need help soon... I'd like to get the install done by the end of tomorrow.
Old Jun 30, 2003 | 09:17 PM
Adi Radoncic's Avatar
On Fire!
Default Re: (turbo2000)
Try bending the dipstick and adjusting it that way....
What else do you have problems with??
Adi
Old Jul 1, 2003 | 05:50 AM
DeepSi's Avatar
Default Re: (newgsr)
yep, you have to bend the dipstick or the actually turbe the dipstick goes in. It should work. Do not put to much pressure on the tube, as it could break off
Old Jul 1, 2003 | 06:15 AM
turbo2000's Avatar
Default Re: (DeepSi)
So i just bend the dipstick and pull it out from the side? I'm not suppose to bend the tube right? I just dont wanna mess anything up.
boost fed ls
Sep 3, 2003 07:47 PM
vteckiller
Jul 21, 2002 07:25 AM
Evil EG
Apr 17, 2002 02:26 AM
GSRrR
Sep 15, 2001 07:39 PM
