input please
Old Feb 3, 2011 | 11:55 AM
94civicgsr's Avatar
Default input please
i am just asking for a little input on my build. i have a gsr block sleeved, 83mm cp 9.0:1 pistons, eagle h beam rods, fidanza flywheel,i spun a rod bearing and didnt know what crank to use looking into eagle,vitor x intake, acl bearings, arp headstuds and rod bolts, 70 mm throttle body, hondata s300, walbro 255, looking for around 500 on pump gas with a gt28r or 30r.any help would be greatly apprectiated
Old Feb 3, 2011 | 01:59 PM
habib's Avatar
Default Re: input please
Just get another gsr crank, stock cranks can hold alot of power.
Old Feb 3, 2011 | 03:28 PM
94civicgsr's Avatar
So I just need my crank turned and oversized bearings
Old Feb 3, 2011 | 03:44 PM
habib's Avatar
If you feel comfortable goin that way then yea
Old Feb 3, 2011 | 04:17 PM
94civicgsr's Avatar
My input I want is the combonation of parts going to work well with each other
Old Feb 3, 2011 | 04:27 PM
sanman000719's Avatar
10 under is fine man hell i ran all sumer with a 20 under stock crank lol with no issue what so ever.
turn it get some bearing good to go homie
habib's Avatar
what injectors you goin to be using
Old Feb 3, 2011 | 04:34 PM
94civicgsr's Avatar
Rc 1000
Old Feb 3, 2011 | 04:51 PM
1 wally might not be enough
Old Feb 3, 2011 | 05:17 PM
94civicgsr's Avatar
So do i go dual or a bosch 044 inline
Old Feb 3, 2011 | 05:37 PM
either or i would think
t1 has a chart that sheds alot of light to this you need me to post it up
Old Feb 3, 2011 | 05:54 PM
habib's Avatar
The chart deals with running the id injectors, the results will vary but will help a little on hp capabilities.
Old Feb 3, 2011 | 06:07 PM
true to a point but is a great referance guide
Old Feb 3, 2011 | 08:46 PM
94civicgsr's Avatar
Will the 1000 peak and hold need anything else to install
Old Feb 3, 2011 | 08:52 PM
TheShodan's Avatar
Moderator
I would use the correct bearings, not oversized
Old Feb 4, 2011 | 04:36 AM
Turbo-LS's Avatar
do not turn the crank, there cheap enough get another stock crank. Eagle cranks are junk
Old Feb 4, 2011 | 06:16 AM
94civicgsr's Avatar
What's the pros and cons of a eagle crank
Old Feb 4, 2011 | 06:21 AM
habib's Avatar
Whats wrong with having the crank turned?
Old Feb 5, 2011 | 04:30 AM
Turbo-LS's Avatar
there only hardened on the outside of the journal, machine it and you lose that. and no shadytree mechanic is going to know the honda hardening process to restore the journal back to honda specs.
orod917
Engine Machining & Assembly
May 13, 2019 10:38 AM
91(si)hatchey
15
Apr 28, 2009 07:35 AM
H9Omega
Mar 18, 2007 08:51 AM
94civickid
Mar 15, 2005 02:10 PM
JSPECHB
Dec 21, 2004 01:17 PM
