Installing new rod bearings. Crank question?
Old Dec 8, 2004 | 04:42 PM
JSPECHB's Avatar
Default Installing new rod bearings. Crank question?
I'm building my block and I'm installing new rods and bearings, but keeping the OEM crankshaft. Does the crank need machineing to mate the new bearings?
Old Dec 9, 2004 | 08:42 AM
PrettyLude's Avatar
pm earl on this, he should be able to tell you
Old Dec 9, 2004 | 09:14 AM
RyanEJ8's Avatar
Default Re: Installing new rod bearings. Crank question? (JSPECHB)
You should have the journals micropolished and make sure everything is within spec still.
Old Dec 9, 2004 | 04:04 PM
JSPECHB's Avatar
Default Re: Installing new rod bearings. Crank question? (RyanCivic2000)
Anyone have price on getting the crank micropolished? My engine right now is perfectly fine. Only has about 60k on it, and it still runs. I'm just rebuilding the block for boost applications. Although I'm keeping the stock crank *maybe* and keeping the stock sleeves. I am just installing the rods with eagles and the pistons with arias.
Old Dec 9, 2004 | 06:57 PM
PrettyLude's Avatar
pm earl up
Old Dec 20, 2004 | 08:02 PM
bunnyrabbit's Avatar
you shouldnt have to micropolish the crank-- have crank journals measured to make sure they are within the right sizes--- order some ACLs from camp1320--- throw them in-- plastigauge everything a few times-- make sure you are good--- and thats it-- i did it and put 228 to the ground on pump gas
Old Dec 20, 2004 | 08:55 PM
V-SPEC 1's Avatar
Getting the crank micro polished is around $25-35.
Old Dec 20, 2004 | 10:18 PM
mmuller's Avatar
Mad Scientist
remember that micropolishing will change your bearing clearances a little
Old Dec 20, 2004 | 11:41 PM
Wht-Blk dc2's Avatar
u should have the cranked remachined and balance, it actually dosent cost that much and you'll be happy with the outcome.
Old Dec 21, 2004 | 01:17 PM
honda does an excellent job with balancing their cranks-- most of them may be off by a few grams or so-- i wouldnt touch the journals, i would have it balanced for sure-- i balance all cranks when building motors
Z0831xiz
Apr 26, 2015 03:56 PM
garados
Jan 25, 2004 03:48 PM
S13 slide
Dec 2, 2002 05:54 PM
