Input for my turbo lude setup
Old Nov 12, 2002 | 09:37 AM
h224life's Avatar
Default Input for my turbo lude setup
ok heres what im wanting to do:
t3/t4e ball bearing with a 60 or 63 trim (which one???cant decide)
f-max open loop DP, manifold, and intercooler/piping
vafc hack
440s
colder plugs
profec B
tial wastegate
greddy bov
oh yeah, open downpipe, permenantly.
if this turns out how i think it should, it will be killer.... what do you think?
Old Nov 12, 2002 | 10:15 AM
Boostless97Lude
Guest
Posts: n/a
Default Re: Input for my turbo lude setup (h224life)
60 trim
build then engine, a stock H22 won't hold at high boost for long
other than that, sounds good
[Modified by Boosted97Lude, 2:15 PM 11/12/2002]
Old Nov 12, 2002 | 11:03 AM
mos's Avatar
mos
Default Re: Input for my turbo lude setup (Boosted97Lude)
Maybe buy a plain bearing turbo from cheapturbo.com and spend the extra money you're saving on a better fuel setup?
Old Nov 12, 2002 | 11:05 AM
I Like Boost's Avatar
Default Re: Input for my turbo lude setup (mos)
open dp is fun
Old Nov 12, 2002 | 11:10 AM
sagaprelude's Avatar
Default Re: Input for my turbo lude setup (BEe18SeAONe)
e trim turbos wont fit an fmax manifold, unless u add a spacer
Old Nov 12, 2002 | 11:11 AM
b16ahybrid's Avatar
open dp is fun
Yeah i ran that for two days when i lost the donut between the downpipe and exhaust housing.It happend on a satuday night so i couldn't get a new on until monday.car was loud,but ran like ****..idle was all fucked up and the lovely smell of exhaust filled my car......ahhhh great times.....
Old Nov 12, 2002 | 12:57 PM
h224life's Avatar
Default Re: Input for my turbo lude setup (b16ahybrid)
oh i know the h22 wont hold at high boost, i would probably leave it at 7psi permenantly
the e series turbo will fit if i put in a t3 flange in between the manifold, and just get some longer screws
im keeping the ball bearing because it being a bigger ball bearing, i figure that the ball bearing will compensate for the little bit longer lag, and that the open downpipe will nearly eliminate the lag..... that way, its a nice low end and top end with the e series..... get my drift?
i think a guy on prelude online did this setup once before....
Old Nov 12, 2002 | 01:05 PM
Boostless97Lude
Guest
Posts: n/a
you better get a boost controller that leaves the wastegate closed until it reachs full boost
there is no such thing as a big turbo that spools fast, and an open downpipe does not neccesarily mean it will help reduce lag
Old Nov 12, 2002 | 01:08 PM
h224life's Avatar
well its not a t60
think about it, an e series, ball bearing, and open downpipe. two things that greatly reduce lag. on a bigger than average turbo, on a 2.2
maybe im wrong....?
Old Nov 12, 2002 | 04:23 PM
Boostless97Lude
Guest
Posts: n/a
no, you are most likely right, but i'm just saying that you can do to much to reduce lag, which actually doesn't reduce lag...... i know that doesn't make much sense but the more you think about it, the more snese it will end up making
Old Nov 12, 2002 | 06:36 PM
GraphiteAccord's Avatar
read boosted97lude's signature. it explains him perfect.
setup sounds nice though, need some other type of management though, but i can't say much, i have the v-afc hack too...why such a large turbo for such little psi? that thign will lag quiet a bit for only 7 psi.
Old Nov 12, 2002 | 06:47 PM
Boostless97Lude
Guest
Posts: n/a
Default Re: Input for my turbo lude setup (GraphiteAccord)
hehehe.. which part exactly?
Old Nov 13, 2002 | 08:53 AM
h224life's Avatar
i see where youre coming from, but im for maxing my performance without maxing out my engine.... thats why im doing open loop, open dp, and ball bearing.... thats why i dont think there will be too much lag with the e series
i talked to the guy on prelude online that had this setup and he made 254hp, that includes the vafc hack that he was using. its actually a good fuel setup, just white trash.
NBPdEeCeE
Aug 17, 2007 01:12 PM
LsNrG
Jan 6, 2005 06:12 AM
Terrabomb
Jul 16, 2004 11:11 AM
dunkd
Mar 10, 2004 06:20 AM
kungfujap
Jun 3, 2003 10:39 AM
