spark plug advice
Old Oct 28, 2002 | 06:35 PM
Boostless97Lude
Guest
Posts: n/a
Default spark plug advice
yes, i did a search, but the only thing i found was about OEM NGK plugs, but what i want to know is, what are the best plugs to use with turbo?
Old Oct 28, 2002 | 06:38 PM
T25 civic's Avatar
Default Re: spark plug advice (Boosted97Lude)
I need to know this also. I have a d16y7 with a t-25 turbo, boosting about 5-9 lbs. What are the best plugs to use for my motor with my setup?
Thanks,
Nick
Old Oct 29, 2002 | 04:12 PM
T25 civic's Avatar
Default Re: spark plug advice (T25 civic)
anyone?
Nick
Old Oct 29, 2002 | 05:22 PM
camp1320.com's Avatar
the plugs you should get are NGK and i have them in stock.>! these are cold plugs NGK V power Racing.... its r567a1-8 or r567a1-9..!!they sell for at about $3.49 each... you can find them for about $2.00- $2.50.. i have them all in stock..
Old Nov 3, 2002 | 11:13 AM
T25 civic's Avatar
Default Re: spark plug advice (camp1320.com)
I've never heard of that part number? What kind would you recomend for my d16y7? I have a set of ZFR6F-11's sitting in front of me, but someone told me to use some kind of BCPR7es-11 or something like that.
Nick
Old Nov 12, 2002 | 10:43 PM
those are fine to for stock boost..!! the bcpr7es-11 are good..!! i got those too for $2.50 each
Old Nov 12, 2002 | 10:47 PM
sporkcrx's Avatar
bcpr7es-11
that's what i"m using.
Old Nov 13, 2002 | 04:36 AM
brian b's Avatar
New User
if your fairly low 5-9psi boost on a d16y7 you wont get the benefit from the r567a1-8/9.. run the bkr7e, bcpr7es or zfr7f they're basicly all the same unless you need extra clearance due to aftermarket pistons or milled head or something.. You can try to run the ZFR6F's but they will most likely cause preignition, you can always put them in and listen
Old Nov 13, 2002 | 07:44 AM
BoostedBB6's Avatar
So for a higher boosted car you should run the R567a1-8 or a1-9 ? I run 12psi. daily on my 5th gen Lude and I am currently running the ZFR7F11's and they are still not the right plug. So the one's that you are refering to are what I need?
Old Nov 13, 2002 | 09:26 AM
KCHybrid's Avatar
Default Re: spark plug advice (BoostedBB6)
I would like to know this as well, I plan on 10 daily and arond 14 on the weekends.
TravisBiggie
Jul 23, 2012 03:25 PM
katzenjammer84
Honda Civic (2001 - 2005)
Jul 8, 2009 07:55 PM
lifes_simple
Aug 21, 2007 06:23 AM
lilintegra25
Jan 16, 2007 07:52 PM
SpeedMonkeyRacing
Apr 24, 2003 08:55 PM
