View Poll Results: Which injectors for my T70 400whp setup
650cc
0%
750cc
46.67%
880cc
20.00%
1000cc
33.33%
Voters: 15. You may not vote on this poll
injector size help!
Old Jan 8, 2009 | 04:45 AM
cuzzfolk99's Avatar
Default injector size help!
hey ppl im in the market of looking for injectors. My setup is as follows t70 turbo srp low comp pistons eagle rods, MSD SCI, victor x Mani, head studs ,cometic head gasket, and crome all this is on a b16 in my si and im needing to know what size injectors i should use ive herd some guyz using 1000 cc injectors and some running 750cc my goal is to get as close as possible to 400whp and people are telling me that should be no problem. So i really need your opinion on what size to i would rather have too much rather than not enough. Thanks for all your help guys.i would like to get info from some peoples setups that are in the 400whp range as well and the 400 whp on pump also the car will be driven about a hour almost every other day if that has to factor in
Old Jan 8, 2009 | 07:09 AM
cuzzfolk99's Avatar
Default Re: injector size help!
bump ttt
Old Jan 8, 2009 | 07:26 AM
miller's Avatar
The 750's will be a good suit for your needs.
Old Jan 8, 2009 | 08:04 AM
twkdCD595's Avatar
t70 huh... i smell ebay chinese turbo. beyond that though kind of a laggy choice for 400whp.
x2 on the 750's though... should be good from what you see from other setups on here around that power level.
Old Jan 8, 2009 | 08:31 AM
Turbo-LS's Avatar
Those ebay "t70" turbos are more like a 50 trim comp wheel with an s cover and a huge turbine housing unless you find the rare ones that are essentially sc61 compressor specs again with the large turbine housing but 750's should be plenty of injector.
I agree with TWKDCD595 much better turbos for the application
Old Jan 8, 2009 | 09:33 AM
sleepencivic's Avatar
get the 1000's you will allways want more power
Old Jan 8, 2009 | 10:10 AM
91TurboGSRCRX's Avatar
plus1 1000cc
Old Jan 8, 2009 | 10:15 AM
twkdCD595's Avatar
if you are considering getting 1000's, get the new bosch saturated units instead of peak n hold with a resistor box imo.
Old Jan 8, 2009 | 11:38 AM
cuzzfolk99's Avatar
well i got the turbo from a guy around here it is a hybrid a garrett 60 trim center section and exhaust with the ebay t70 compressor side made 469 on his built ls vtec on 15 psi and the turbo is just a temp for now until i find something like a full garrett 60 trim with the t3 flange .60 .63
Old Jan 8, 2009 | 11:51 AM
Turbo-LS's Avatar
x2
Old Jan 8, 2009 | 12:38 PM
cuzzfolk99's Avatar
I think im going 750's since i will be driving the car considerably alot lol with a walbro 255
Old Jan 8, 2009 | 10:53 PM
beastsohc's Avatar
dont matter how much you drive. go with the 1000s. you wont stress the injectors
Old Jan 9, 2009 | 03:18 AM
HondaKyle's Avatar
1000cc
Old Jan 9, 2009 | 04:11 AM
TunerToys's Avatar
Are you planning to make 469 as well? If you are aiming for this goal, and your engine is built to handle it, that's fine. However, if you are only planning for 350 or 400hp, you might want to consider a smaller turbo. On a 1.6 to 1.8Liter engine, aiming for 400Hp is easily achieved with the basic T3 57Trim Garrett. This is a turbo you can get brand new in the $500 range.
My point is this, you should buy the smallest turbo that will achieve your goal. If you hang a 1000hp capable turbo on a motor that you are only going to boost to 8psi, it's going to be so mismatched that the performance will be horrible. The same engine, with a properly matched turbo, will be a blast to drive, even at 8psi.
Hope that helps, and doesn't confuse.
Craig
Old Jan 9, 2009 | 04:28 AM
cuzzfolk99's Avatar
yes i understand that im looking to get 4-450 for now and later on go more but the motor is built to the same specs as my buddies integra just not ls vtec but hes running a b16a2 now with t he same turbo and setup and it getting about 420ish to the wheels with the same turbo and 14psi
Old Jan 9, 2009 | 06:43 AM
cuzzfolk99's Avatar
now im looking at a t4 garrett turbo its actually a t3/t4 hybrid with a .63 exhaust side and i believe it a 57 trim compressor side how would this be matched for my plans?
lsd96teg
Dec 18, 2010 11:46 AM
EK79
May 13, 2007 10:14 PM
alexb16hb
May 13, 2006 10:18 AM
89SiR
Mar 10, 2003 03:27 PM
Dancing is Forbidden
Feb 17, 2003 11:01 AM
