Injector Size?
Old Mar 10, 2003 | 02:50 PM
89SiR's Avatar
Default Injector Size?
I did a search and didn't find any answers. I have a B16 that I am planning to run higher boost with (somewhere around 18PSI). I will be using the Zdyne Gold ecu and I will be adding a small amount of Nitrous just to spool the turbo (track use only) otherwise I will be running about 10psi on the street. Just wondering if my 450cc injectors will do or should I upgrade to higher cc injectors. Any help would be great.
Thanks!
Old Mar 10, 2003 | 02:56 PM
alpha's Avatar
Default Re: Injector Size? (89SiR)
What size turbocharger, what else do you have, etc.? With that information you will get better answers.
http://www.rceng.com/technical.htm#WORKSHEET
Diego Boost's Avatar
@ 18psi you'll be pushing those 450's to the limit. Go with some 550's or higher.
Old Mar 10, 2003 | 02:59 PM
89SiR's Avatar
Default Re: Injector Size? (0x64)
I have a Turbonetics T3T04E .63AR
Old Mar 10, 2003 | 03:14 PM
89SiR's Avatar
Do you think 750's would be overkill?
Old Mar 10, 2003 | 03:22 PM
alpha's Avatar
I don't think they will be over kill. What are your HP goals? I went with MSD 72 lb/hr (756cc) injectors. Larger than I needed but leaves room for more power.
Old Mar 10, 2003 | 03:25 PM
89SiR's Avatar
I'm not even sure what horse power I will get. The motor is fully built so it can withstand the higher boost. Any rough ideas what HP I'll get at around 18psi?
Old Mar 10, 2003 | 03:27 PM
dfoxengr's Avatar
id run 550s...and an AFC theyll work fine together
clicky79
Nov 5, 2018 12:53 PM
TeggieeTuner
Dec 3, 2009 03:11 PM
Charlie Moua
Oct 28, 2009 11:09 AM
alexb16hb
May 13, 2006 10:18 AM
s2kkid
Jul 13, 2005 04:59 AM
