FMU sticking question
Old Aug 15, 2002 | 05:34 PM
Hybrid's Avatar
Default FMU sticking question
If the fmu (vortech) plunger were to stick, would it stick up, or down?
If it sticks down, would that mean that its raising the pressure as much as it can (similar to 12:1 disk?)
Cause when I take the top off my fmu to access the disk, my plunger is down all the way. I want to eliminate this concern from my head without taking the thing apart ya know.
Old Aug 15, 2002 | 07:17 PM
skilzz's Avatar
Default Re: FMU sticking question (Hybrid)
Never opened one up before man but simple check...get a fuel pressure gauge/tester and take her out one time, that should tell u all u need to know.
Old Aug 15, 2002 | 10:46 PM
shadowdawn's Avatar
Default Re: FMU sticking question (maddskilzz)
Not sure if it helps, but normally when it sticks it makes you run REAL rich so I'm assuming your correct in that you are running insane fuel pressure when its stuck.... which is
Old Aug 16, 2002 | 02:56 AM
Hybrid's Avatar
Default Re: FMU sticking question (shadowdawn)
Well I guess its not stuck then cause the car starts and idles just fine, hence indicating a not too too rich condition.
EG_GSR
Jan 8, 2007 11:49 AM
Go Fast Civic
Dec 1, 2004 01:08 PM
uneekcrx
May 27, 2002 06:41 AM
uneekcrx
Apr 26, 2002 08:16 AM
revhrdls
Nov 13, 2001 03:16 PM
