fuel pressure????
Old Jun 6, 2004 | 10:25 PM
bluesi00's Avatar
Default fuel pressure????
i searched already but couldnt find this. i found what it should be stock but here it goes. what should my fuel pressure be at on a 00 civic si with a 255lph walbro intank fuel pump?? thanks
Old Jun 7, 2004 | 03:30 AM
FOrSfEd's Avatar
Default Re: fuel pressure???? (bluesi00)
If you are running stock injectors 38-45psi. Start low and turn it up a little bit at a time to where the car feels good.
Old Jun 7, 2004 | 07:03 AM
bluesi00's Avatar
how can i turn it up? i do have stock injectors and i have a fmu but and i have the stock fuel pressure regulator
Old Jun 7, 2004 | 07:09 AM
Muckman's Avatar
Moderator in Chief
Default Re: (bluesi00)
You can adjust with the FMU if its adjustable.
My idle pressure is about 50psi with stock rail and fpr driven by a walbro 255.
hondaeg8's Avatar
get an adj fpr. without an adj fpr, your car is going to run rich, especially with the fmu. when i had mine, my fuel pressure at idle was around 60psi.
Old Jun 7, 2004 | 07:26 AM
bluesi00's Avatar
thats the thing, i asked this question because i should be running rich but im running lean. i had a question. i had some 880s in and now that i put the stock inj back on its running lean for some reason, everything is back to stock and its running lean. could it be a distributor problem? cause i got oil in there from the oring going bad
Old Jun 7, 2004 | 08:01 PM
Pengo's Avatar
is ur fmu adjustable like muckman suggested? cuz that's the only solution i see without having to change anything else.
the fmu would have to be restricting pressure by alot for you to idle those 880s if that's the only management you've got.
throw those stockers back in with the same fmu, and now ur getting less fuel than stock. therefore ur lean condition. you can try taking out the fmu and make sure it runs fine like that.
Old Jun 7, 2004 | 09:04 PM
bluesi00's Avatar
it runs the same with or without the fmu. im getting a cel 67 which is the catalytic converter.
Kr4nG
Sep 28, 2009 02:31 AM
GsrIntegra789
Jun 4, 2008 04:00 PM
astig* DC2
Jul 13, 2005 02:04 PM
IVANITR
May 6, 2002 07:16 PM
