Installed SAFC......
Old May 10, 2003 | 03:24 PM
ntegls's Avatar
Default Installed SAFC......
Installed my SAFC a couple days ago, car feels normal, no check engine light, setted sensor/cylinder. Everythings seems correct but I just want to know if I should get anykind or readings from AFL (air flow), Kar (karman), Cor (Correct)?? I get readings from throttle and rpm and I did get readings from AFL but not anymore (weird...).
Old May 10, 2003 | 03:40 PM
boosted_dc2's Avatar
Default Re: Installed SAFC...... (ntegls)
you will not get a reading from Karman unless you are running a dsm, COR stand for correction and youll only see soemthing on that if you are richening/leaning the mixture. And i think to see anything on air flow you have to hook up th blue wire to your air/fuel wire at your computer. then you have to go into the sensor menu and select it. Im not sure if this is right though but im sure somebody on here does.
Old May 10, 2003 | 05:25 PM
Johnyquest's Avatar
You need to select sensor type PRESSURE and number 6 for IN and OUT settings.... or else your afc is going ot be doing some funky shitttt!
Old May 10, 2003 | 05:38 PM
Westrock2000's Avatar
Default Re: (Johnyquest)
Ya you should have Pressure selected, and it should read like -600 mm/hg (or whatever) at zero throttle then like ~0 at 100% throttle. And the COR will show up if you actually do any adjustments. Like if you do the AFC hack with forced induction it will read like -35% (or whatever) all day long
Old May 11, 2003 | 03:22 PM
ntegls's Avatar
Default Re: (Westrock2000)
Thanks everyone, its just so weird how the first day I finished installing I was getting some readings from Air Flow, but now it gets no readings.
Oh well, I must have been trippin out
Old May 19, 2003 | 10:40 PM
TurbochrgedTIBBI's Avatar
Default Re: (ntegls)
How does one determine the settings to use for pressure sensor (i.e. 6 in 6 out)???
freeplay
Nov 16, 2002 05:42 AM
arw321
Oct 2, 2002 05:08 PM
CzanSOHC
Sep 3, 2002 08:06 PM
SilverIntegra
Apr 16, 2002 11:32 AM
austrian type-R
Sep 17, 2001 12:41 PM
