Injector question???
Old Dec 25, 2007 | 09:03 AM
perseverance's Avatar
Default Injector question???
wassup guys, i figured i'd ask here. I have a built ls/vtec and i'm running 450cc injectors and my tuner told me i'd be good with 10psi on my t304e turbo. Well i'm building another ls/vtec boost setup for my EK. This one will be using an innovative t3/t4 turbo, a ramhorn style manifold and 3" exhaust. I was wondering what size injectors i should run on this setup? I'm looking to run 15psi on the weekends and 6psi for daily driving. I don't want to go over 7000 rpm on this setup...even tho i'm sure i'll still be making power. My current setup has lasted over 4 years now. I want this one to last just as long. Would u prefer 680cc or 880cc injectors for this setup? thanks a lot in advance. and Merry X-Mas!
Old Dec 25, 2007 | 09:07 AM
boosstboy's Avatar
Default Re: Injector question??? (perseverance)
you can get away with the 680's but 880's have high safety margin in case you turn up the boost more or get a bigger turbo later.
Old Dec 25, 2007 | 09:09 AM
that's what i was thinking about the 880's....but will 880's still get me some good gas mileage for daily driving cause i don't wanna go over 6psi daily.
Old Dec 25, 2007 | 09:12 AM
boosstboy's Avatar
Default Re: (perseverance)
your gas mileage depends on the tune. your idle should be ok with the 880's, what program are you using to tune with. i run 750's i mine with a aem. my car get's like average 25mpg street mostly.
Old Dec 25, 2007 | 09:16 AM
we'll be using crome... i had hondata but got rid of it. I'm just worried about idle like u mentioned...i'll ask the tuner when i get a chance.... i might look into the 750's tho since that's in the middle of what i was looking for.
Old Dec 25, 2007 | 09:24 AM
boosstboy's Avatar
fuel pump and fuel pressure and a 1 to 1 rise regulator play roles to in selecting injectors too. on boost setup's using a rising rate regulator helps in tuning (more controlled fuel map) and can decrease injector sizing.
Old Dec 25, 2007 | 09:28 AM
I used stock fpr on my current build, but a walbro 255 fuelpump. Maybe this time around i'll get an aem fpr and fuelrail. thx for the help boosstboy.
Old Dec 25, 2007 | 09:33 AM
boosstboy's Avatar
no prob, but i dont believe the aem rugulator is a 1.1 rise. aeromotive has rising rate regulator's. if you buy one make sure it says, rising rate or 1.1 boost reference. the a1000 efi is my choice.
Old Dec 25, 2007 | 10:41 AM
Lmgrcivic's Avatar
Default Re: (boosstboy)
just get you some 750's and a good tune and you will still be able to get good gas milage and you can rev that out to 7500 and be good
Prozon
Feb 26, 2011 07:41 PM
BoostinTEG
Jan 12, 2011 10:45 AM
crxkid24
Oct 13, 2005 08:09 PM
X2BOARD
Jul 8, 2004 11:22 AM
JGurr81
Dec 3, 2003 07:19 AM
