what injectors for boosted ls vtec
Old Oct 10, 2005 | 09:57 PM
crxkid24's Avatar
Default what injectors for boosted ls vtec
i have a fully built ls vtec and i'm going turbo. i dont know what injectors to run. i plan on running 15 psi with a garrett t3/4. i plan on getting rc injectors i just dont know what size. 550's or 750's? peak and hold or saturated? lmk what you guys think. thanks.
Old Oct 11, 2005 | 03:55 PM
hotimportcrx's Avatar
Default Re: what injectors for boosted ls vtec (crxkid24)
the size depends on how much boost your planning to run....also saturated injectors are good for obd1...and obd0 peak and hold are good for....peak and hold injector require the use of a resistor box...or youll put to much pressure on the ecu and burn it out
Old Oct 11, 2005 | 04:36 PM
TurboCoop's Avatar
Default Re: what injectors for boosted ls vtec (hotimportcrx)
RC 750's would be perfect for about 15-20psi
Old Oct 12, 2005 | 07:59 PM
crxkid24's Avatar
well ill be running between 10-15 psi no more than 15 though. so would i be okay with 550's?
Old Oct 13, 2005 | 05:10 AM
TurboCoop's Avatar
Default Re: (crxkid24)
Im running DSM 450's on my LS/Vtec turbo, and we maxed them out while tuning at like 13 or 14psi. If you dont ever plan on upgrading and adding more boost then 550's will be fine. But Id spend a few extra bucks and have them for when I want to upgrade. Its just as easy to tune with 750s as 550s, its up to you though. 550s wold definitely work if you dont want to go over 15psi, they would probably be at like 70% duty cycle max(rough guess).
Old Oct 13, 2005 | 08:09 PM
crxkid24's Avatar
sweet thanks for the info man.
vartok
Feb 16, 2013 08:58 PM
mrccupid3
Dec 8, 2008 07:06 AM
cherroneballs
Mar 23, 2008 12:10 PM
blackblack
Dec 26, 2007 06:49 PM
Rod.
Sep 19, 2003 03:10 PM
