turbo b16 project, i have a few questions
i have everything done on the b16 and i ordered some 390cc injectors that are going to take a week and a half to get here. i was wondering if i could use my stock b16 injectors to run the car till i get the new injectors. what problems will i have if i use the stock injectors and how much boost can they handle.
Re: turbo b16 project, i have a few questions (blackcrx16)
What engine management are you using? You can use your stock injectors for the time being, but I wouldn't go into boost until you get the larger injectors/get the car tuned.
Re: turbo b16 project, i have a few questions (herecomesboost)
i have no engine management except for a safc2 right now, i am going to put some 390cc injectors in and then get tuned when i get some money.(next pay check) if i put the 390's in and get it tuned can i run 9psi on a stock b16 with a port n polished head whith gsr cams? would that be safe for an every other day driver?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackcrx16 »</TD></TR><TR><TD CLASS="quote">i have no engine management except for a safc2 right now, i am going to put some 390cc injectors in and then get tuned when i get some money.(next pay check) if i put the 390's in and get it tuned can i run 9psi on a stock b16 with a port n polished head whith gsr cams? would that be safe for an every other day driver?</TD></TR></TABLE>
First off what turbo? And all stock motors give out sometime down the road, you'll never know.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dturbocivic »</TD></TR><TR><TD CLASS="quote">fmu + stock injectors FTW !!!!!</TD></TR></TABLE>
900% injector duty
900% injector duty
Re: turbo b16 project, i have a few questions (awdgsx96)
its a pretty small turbo, ar 48 if that makes anysence to you guys, i think its a t3. and also another question, is there anyway to do something with the map sensor so it stops throwing a code. i did the missing link thing and i put a 5.8psi spring in my wastegate and it still throwing the code when i get to 5.8psi and starts to break up. if the map sensor causing the car to break up?
What year is the B16 out of?
I think the EM1 is the only B16 that has a map that will allow boost and I believe its limited to ~11 psi
