how much boost on stock injectors?
Old Feb 5, 2006 | 12:32 PM
AJxr's Avatar
Default how much boost on stock injectors?
my setup with be a d16a6, std mani, .42 .48 t3, 2.5 pipes all around, s14 SMIC, and turboedit for management.
my question is can i run 2-3lbs of boost on my stock injectors? ive heard of people running 12 psi and not even maxing out 450cc so shouldn't i be safe around the said levels of boost on the stock 240cc injectors?
btw this is just temp. until i get ahold of some 450s and someone to tune my care well, up to 8psi.
Old Feb 5, 2006 | 12:39 PM
project dc2's Avatar
Default Re: how much boost on stock injectors? (AJxr)
hrmm i woudlnt bother ... stock injectors are already pretty much at about 67% duty cycle at wot .. however you need to account that its not runnin at 11:5- 12:1 AFR. once you add positive pressure to you've already exceeding the 85 duty cycle recommend theshold at 7500 RPM and 2 psi of boost
Modified by project dc2 at 2:10 PM 2/5/2006
Old Feb 5, 2006 | 12:45 PM
stealthmode62's Avatar
Default Re: how much boost on stock injectors? (project dc2)
The feeling of needing to rush things is what kills motors. Doing what you're trying to do is like asking if you'll be ok to drive around town with one lug nut on each wheel. Just don't do it. There's no point.
Old Feb 5, 2006 | 05:56 PM
xenocron's Avatar
Default Re: how much boost on stock injectors? (stealthmode62)
I ran 5psi on stock 240cc injectors in my LS. I also jacked the base fuel pressure up to 55psi though before doing so...
Old Feb 5, 2006 | 06:02 PM
Default Re: how much boost on stock injectors? (xenocron)
Hardly sounds like a reason to do it.
Old Feb 5, 2006 | 08:44 PM
SiAutoX's Avatar
i have injectors ill sell you! 525cc
Old Feb 5, 2006 | 08:50 PM
CoreyR's Avatar
Default Re: how much boost on stock injectors? (EF'n Turbo)
im running 7psi on a 14b stock D16A6/stock 240cc and my wideband tells me in in the high 10's low 11's at WOT in the upper RPM's.
Old Feb 5, 2006 | 08:58 PM
I Have an STD's Avatar
wrenchin'
Default Re: how much boost on stock injectors? (CoreyR)
at what fuel pressure?? how long do you think those injectors will last at over 100% duty cycle?
Old Feb 5, 2006 | 09:03 PM
CoreyR's Avatar
Default Re: how much boost on stock injectors? (I Have an STD)
stock fuel pressure. i dont care how long they last honestly im waiting for it to blow up so i can stuff my Z6 into this car.
boostcrazy1234
Apr 14, 2008 10:19 AM
DrivinVtec
Jul 21, 2006 08:22 AM
blackfoot
Jan 22, 2006 08:01 AM
project civic
Sep 5, 2005 04:07 PM
turbocivic22
May 11, 2003 04:39 PM
