Incorrect Block Guard install>>?>>
Old May 20, 2005 | 03:52 PM
  #51
kobi2002's Avatar
Default Re: (kobi2002)
Did not dyno only street tune and I ran on 16psi for over two years now. No blockgaurd. So yes I can say from real life experience It's not needed. I think a block gaurd gives a false sense of security
If you want a strong block go sleeve's. Do it all or nothing, cause I know way to many people run without them including myself with no problems
Old May 20, 2005 | 03:59 PM
  #52
kobi2002's Avatar
Default Re: (Clone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Clone &raquo;</TD></TR><TR><TD CLASS="quote">No golden suggest's getting it welded in and then machined.This method is if you already have your pistons in and want to use a block gaurd without having to get it machined.Was is it? People dont understand what they read? Read it again Ive been rewording my sentances so that people understand.Im not being rude but alot of people on HT have poor reading comprehension.
I believe using a block gaurd keeps the sleeves in one piece in the event that it cracks.Better to crack than have chunks going in the cylinder because no block guard was installed.</TD></TR></TABLE>
Sorry but I've seen sleeve's cracked into chunks with blockgaurds. I don't think that matters anyway because the whole point is for your sleeve's not to crack. Right??
Old May 20, 2005 | 04:05 PM
  #53
Kevin's Avatar
Default Re: (Junglesnake)
Ive always thought that the cracking that occurs in most open deck blocks was caused by the materials used to build it, overheating or detonation. How does a block guard solve any of these problems?
Old May 20, 2005 | 04:15 PM
  #54
kobi2002's Avatar
Default Re: (raceboat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raceboat &raquo;</TD></TR><TR><TD CLASS="quote">Ive always thought that the cracking that occurs in most open deck blocks was caused by the materials used to build it, overheating or detonation. How does a block guard solve any of these problems?</TD></TR></TABLE>
That is what I always thought
Old May 20, 2005 | 04:36 PM
  #55
EnzoSpeed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Junglesnake &raquo;</TD></TR><TR><TD CLASS="quote"> Just look around at the amount of people putting down big numbers with stock sleeves and no blockguard.
To each his own.</TD></TR></TABLE>
And just look around at the amount of people with D-series complaining that they blew a headgasket. How do we know that a blockguard wouldn't have stopped the sleeve shifting that caused the headgaskets to blow?
Actually, now this seems like an issue that can't be resolved. I mean, how can you tell whether or not an installed blockguard is helping, or whether a blown motor would have benefitted from one?
thapimpfromchi
Dec 27, 2010 02:23 PM
HyperFlow
Aug 5, 2010 11:11 AM
jeremiah87
Nov 19, 2008 02:17 PM
slug
Jan 21, 2004 10:29 AM
madman604
May 23, 2003 04:19 PM
