sleeves and block guard?
Old Aug 5, 2010 | 05:02 AM
HyperFlow's Avatar
Default sleeves and block guard?
I bought this motor that has block guards and i want to sleeve it, do i gotta remove the block guard or can i have both? sorry i dont even know what a block guard looks like so sorry if its a retarded question :D
Old Aug 5, 2010 | 08:25 AM
Silva Bullit DC4's Avatar
Default Re: sleeves and block guard?
No, there's no need for the block guard with aftermarket iron sleeves.
Old Aug 5, 2010 | 08:29 AM
E85B18's Avatar
Remove it. If it's welded in you may be in trouble if you're trying to sleeve it. Google block guard and Im sure you'll be able to figure out what it is
Old Aug 5, 2010 | 09:52 AM
HyperFlow's Avatar
Do i HAVE to remove if it welded?
Old Aug 5, 2010 | 10:53 AM
E85B18's Avatar
Depends on how it's welded, the sleeves you want to run and the ability of the machine shop. Is the guard welded to the sleeves themselves or just the inside of the block like this (ps my block is sleeved and has a block guard). People say it can cause "hot spots" and cooling issues but I've had zero issues in 4 years:
Old Aug 5, 2010 | 10:57 AM
HyperFlow's Avatar
Thanks, i had good luck with darton sleeves so i will stick with them. hopfully they arnt welded. But with my luck there gonna be. ;/
Old Aug 5, 2010 | 11:11 AM
E85B18's Avatar
Good luck. If they're welded to the stock sleeves or not, its not a big deal. If the guard is welded to the sleeves then you will have to get rid of the guard. The machine shop will cut it all out, which may be the best way for you to go anyway. If I could go back I wouldnt have both... There's no need because the sleeves are strong enough and people do have issues with block guards.
jspeedy
Mar 18, 2004 06:49 PM
FOrSfEd
Feb 28, 2004 04:02 PM
Twenty36_1
Aug 14, 2003 12:32 AM
Soon_2b_evil
Aug 8, 2003 06:40 PM
madman604
May 23, 2003 04:19 PM
