Important Gauges Needed?
Old Aug 10, 2011 | 11:54 AM
  #26
lilnicksta21's Avatar
Default Re: Important Gauges Needed?
thanks guys
Old Aug 10, 2011 | 12:49 PM
  #27
Turbo-LS's Avatar
does it hold the larger screen tunerview though?Last i thought it only held the smaller one ?????
Old Aug 10, 2011 | 01:47 PM
  #28
Spawne32's Avatar
its litterally the same size if not larger then the hole you have that thing stuck in, and it says its supports tunerview2, they are pretty big in person.
Old Aug 11, 2011 | 08:29 AM
  #29
Turbo-LS's Avatar
ill look into it thanks man
Old Aug 17, 2011 | 12:52 PM
  #30
planing on getting these gauges;
Boost: http://www.jegs.com/i/Auto-Meter/105/5903/10002/-1
Oil Pressure: http://www.jegs.com/i/Auto-Meter/105/5903/10002/-1
AFR Wideband: http://www.jegs.com/i/Auto-Meter/105/5978/10002/-1 not too sure on the autometer A/F wideband or if i should go with AEM
and should i get boost and oil pressure in eletrical or mechanical? or which is better for each other, someone told me to get eletrical oil pressure just in case a line leaks in the interior.
Old Aug 17, 2011 | 01:08 PM
  #31
Spawne32's Avatar
the oil pressure gauge is really not something you will ever use, by the time you notice your oil pressure going to **** on the gauge, its too late. put something you would actually have concern about monitoring, like fuel pressure for tuning, or EGT, which is more vital on turbo setups then anything else.
Old Aug 17, 2011 | 01:23 PM
  #32
pcguy760's Avatar
Originally Posted by sdobson910
Im running wideband, boost and oil pressure. Fuel pressure is on my fuel rail but obv cant look at it in the car.
Should not even consider boost without the above AT LEAST!!!!
RacerBoy
Feb 5, 2003 08:55 AM
E Swift
Jun 5, 2002 08:34 PM
Snafu-Si
May 3, 2002 09:27 AM
cyan1de
Dec 11, 2001 10:30 AM
DC2R714
Nov 28, 2001 09:13 AM
