Size of oil return fitting question. -10AN, -12AN which one?
I have this 45 degree bend to my oil pan and I need to get an aluminum fitting instead of steel to weld onto an aluminum y8 oil pan. The problem is, I don't know what size to get.. I went to home depot for measurements, and found a 5/8th fitting but in steel to fit onto the Female section. I found aluminum fittings by Earl's but can't seem to see which one fits my needs.
The only marks I can read on my metal fitting that I have is NP1(T or 0) a reverse E or 3
Here's an actual picture of the setup from before (note, the oil return line has been cut and adjusted.)
Re: Size of oil return fitting question. -10AN, -12AN which one? (wantboost)
Thanks for the quick response. For re-assurance could anyone else confirm this before I purchase this?
