Tuning ignition advance
Old Aug 8, 2002 | 12:18 PM
falcongsr's Avatar
What is this crap?
Default Tuning ignition advance
I have a question regarding how to tune your ignition map...(on any standalone)
assuming you have enough fuel at a given rpm, do you then set your ignition advanced as far as possible without detonating?
my DSM buddy says: " assuming you've got enough fuel, then peak power occurs right on the detonation threshold"
can you be advanced TOO far and lose power without knocking? basically i am saying you ignite the mixture too early and its not optimizing the usage of the fuel...
i'll be tuning without any boost for now, i guess it doesnt make a difference boost vs NA...
Old Aug 8, 2002 | 12:27 PM
dbman96's Avatar
New User
Default Re: Tuning ignition advance (falconGSR)
Yes, power will fall off if you're too advanced or too retarded. Typical tuning procedure is to advance timing until you either hear knock or the power starts to drop, and then retard it until power starts to fall off again - peak power is kind of a plateau effect; as you advance, you should reach peak power and then power should pretty much level off until you hit detonation. You'll never lose a significant amount of power by tuning your ignition a few degrees conservative.
Old Aug 8, 2002 | 12:45 PM
falcongsr's Avatar
What is this crap?
Default Re: Tuning ignition advance (dbman96)
thanks...
what about part throttle, light load? does ignition get advanced farther? why?
Old Aug 8, 2002 | 12:51 PM
falcongsr's Avatar
What is this crap?
is 1044 (mbar) incdicating full load, WOT?
so it looks like timing at part throttle is generally advanced compared to WOT.
thanks to hondata for the map
i am guessign that timing retard around 5000rpm is for the vtec changeover...
bspeed
Engine Management and Tuning
16
Jul 14, 2015 11:22 PM
Turbo E
Nov 3, 2004 10:13 AM
ZhaGg
Jun 14, 2004 12:13 PM
5thgencivic
May 2, 2003 07:14 PM
