Ignition Retard on boosted ITR
Old Mar 10, 2003 | 11:53 AM
swlabhot's Avatar
Default Ignition Retard on boosted ITR
I'm boosting 6.5psi to start with on stock block. Should I retard the timing at the distributor manually? If so how many degrees? 0.5, 0.75, 1 degree/lb of boost?
Old Mar 10, 2003 | 12:56 PM
Diego Boost's Avatar
Default Re: Ignition Retard on boosted ITR (swlabhot)
0.5 per lb/boost is the standard.
Old Mar 10, 2003 | 01:29 PM
swlabhot's Avatar
Default Re: Ignition Retard on boosted ITR (Diego Boost)
Thanks!
NLR
Sep 9, 2006 06:31 AM
CRXLST
Oct 27, 2004 09:45 PM
BEV@GSCMotorsports
May 14, 2004 10:00 AM
boost fed ls
Jul 20, 2003 09:43 AM
Licensed2Spool
Apr 9, 2003 06:22 AM
