Ignition Timing HELP!
Old Jan 3, 2003 | 09:44 AM
echo999's Avatar
New User
Default Ignition Timing HELP!
Ok, I'm working on ignition timing for EMS, and was thinking that
it is definitely ok to run stock ignition timing (load vs. RPM) while
load is non-positive.
then I'll interpolate values for positive boost at a rate of 1 degree of retard
for each lb of boost.
This seem right?
Old Jan 3, 2003 | 10:24 AM
Speedworks801's Avatar
Default Re: Ignition Timing HELP! (echo999)
Yes, you will be fine for starters that way. Probably 3/4ths of a degree is plenty conservative.
Be sure to look at you ADV COMP window in engine parameters and make sure your timing agrees with the timing gun. It will save you a lot of headaches.
[Modified by Speedworks801, 1:26 PM 1/3/2003]
Old Jan 3, 2003 | 10:47 AM
RGAZ's Avatar
New User
1 deg/lb may be too much. Try 0.8 or 0.75. I had horrible high rpm response/stutter with anything more than 0.8 deg/lb.
OK?
Randy
Old Jan 3, 2003 | 12:27 PM
echo999's Avatar
New User
Default Re: Ignition Timing HELP! (RGAZ)
http://www.aempower.com/bbs/viewtopic.php?t=1680
Read this post and d/l my ignition map at then end (not using it yet, but
I think I might be totally crazy)
.RTErnie
Oct 3, 2005 11:18 AM
xcountrirunr
Dec 1, 2004 08:57 AM
zseeanz
Feb 8, 2004 07:23 AM
