If you car is over heating here is a checklist to check your car over
Old 08-24-2005, 11:58 PM
vaporboy12's Avatar
Default If you car is over heating here is a checklist to check your car over
If you car is over heating here is a checklist to check your car.
figure out if it is overheating in boost,idle etc....
if under boost does your coolant reservoir bubble over with coolant
let the car cool down check coolant leave check for leaks
remove radiator cap and bleed the coolant system with heat on for a good 20mins
also during this time make sure fans are working and pull the heat out toward the firewall
test-drive. ok. no move to next step
try the simple stuff first cheap that way.
check and replace thermostat. check coolant hoses, check service on water pump and timing belt
next check engine compression and cylinder leak-down test.
my number showed up low on compression and high on leak-down
chance are that you headgasket is bad
if anyone has anything to add to this feel free to pm me or post it and ill make changes
Modified by vaporboy12 at 4:16 PM 8/25/2005
Old 08-25-2005, 09:16 AM
vaporboy12's Avatar
bump
Old 08-25-2005, 09:26 AM
bubbahatch92's Avatar
Default Re: (vaporboy12)
There is also a problem that I have been having for years with my car overheating on the High way ONLY. There has been a few threads created about it recently (which suprised me because I thought the problem was unique to my car). It is a problem with running half size radiators on B and H series motors, and the cars aero dynamics. The only solution so far is to replace the radiator with a full size radiator, but I should be testing a different solution pretty soon and I'll post it up if it works out. Just thought I'd add this since it's been coming up alot lately.
Darkness
Old 08-25-2005, 09:42 AM
vaporboy12's Avatar
Default Re: (bubbahatch92)
thanks but there got to be a coolant issure when you over heat. ive been running a half core on my bseriers for 3 years with no over heating problem and my intercooler blocks the whole thing greddy type 24
Old 08-25-2005, 09:53 AM
you may think so, but I've gone through it all. I've been doing this **** for a long time and think I know where the problem lies. I've had two different motors, two different radiators, and two different intercoolers. It has alot to do with pressures and aero dynamics. I've done an energy balance on my cooling system and also done a breif analysis on my aero situation and am confident that I have found the problem. I dont know where the link is to the thread where people have been having similar problems, but it equivilates to some times a half size radiator is not enough. I doubt in maryland you see 100+ ambient temps on a regualar basis, and I dont know anything about you chasis or setup, but I guess a half size is good enough for you, bit it's not for every one.
Old 08-25-2005, 12:11 PM
Sketch_hs's Avatar
make sure the damn fan is blowing the right way.
i did it
Old 08-25-2005, 12:33 PM
vaporboy12's Avatar
Default Re: (Sketch_hs)
bump for the add
Old 08-25-2005, 01:24 PM
I've also had about 5 different fans. The one that I found works the best is the slim line fal fan or an oem fan, because the shroud is very imortant. But yeah my fan is turning the right direction.
Old 08-25-2005, 01:47 PM
vaporboy12's Avatar
have you tried to jump the fan so it runs all the time when the car is on
Old 08-25-2005, 01:57 PM
Quad-Damag's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vaporboy12 &raquo;</TD></TR><TR><TD CLASS="quote">have you tried to jump the fan so it runs all the time when the car is on</TD></TR></TABLE>
ya that helps alot
Old 08-25-2005, 02:08 PM
vtec69's Avatar
im also haveing the hwy problem also and have done lots of things to try to fix it
im gonna try to put a piece of cardbaord on the open section were the ac used to be so that the air is forced to go into the rad
Old 08-25-2005, 02:24 PM
vaporboy12's Avatar
Default Re: (vtec69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec69 &raquo;</TD></TR><TR><TD CLASS="quote">im also haveing the hwy problem also and have done lots of things to try to fix it
im gonna try to put a piece of cardbaord on the open section were the ac used to be so that the air is forced to go into the rad</TD></TR></TABLE>
try jumpin you fan on all the time
Old 08-25-2005, 02:29 PM
vtec69's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vaporboy12 &raquo;</TD></TR><TR><TD CLASS="quote">try jumpin you fan on all the time </TD></TR></TABLE>
yeah next time im going to be on the hwy im gonna try that and see how that works
Old 08-25-2005, 02:30 PM
vaporboy12's Avatar
well you can jump so it on all the time when your keys are on works great and all you need is one wire and it takes like 2 mins to do
Old 08-25-2005, 02:33 PM
vtec69's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vaporboy12 &raquo;</TD></TR><TR><TD CLASS="quote">well you can jump so it on all the time when your keys are on works great and all you need is one wire and it takes like 2 mins to do</TD></TR></TABLE>
O yes i know but it doesnt overheat on city driving so id rather not have the fan burn out from over use til i can check it for sure
Old 08-25-2005, 02:36 PM
vaporboy12's Avatar
a fan is morre like to burn out from stop and starting than on all the time
Teamdiesel
40
12-03-2019 04:10 PM
oneludesol
01-04-2010 07:47 AM
lisajasmin
11
05-25-2008 10:42 PM
fanta!
08-14-2005 12:58 PM
Quick Reply: If you car is over heating here is a checklist to check your car over
