ID100cc max hp on E85?
What is the max power these injectors are pumping on e85 fuel on a 4 cylinder car?
Deciding whether they will be enough for my setup.
Why dont ID/T1 make a 1500cc injector for all us guys who want >700whp?
Up the base pressure and they will flow more, but anything over 550whp I would do a dual pump on those ID1000 injectors, but then again I have a friend who made 630 on e85 on precision injectors..but I dont suggest that at all haha
I understand you can run 100psi base pressure and that would give you around 1540cc of flow, I do have a twin 044 surge setup but I wanted to know more or less the figures maxing out on e85 and these.
Someone tell me that id2000cc are streetable on e85
id 2000s rock, they have a vid on there web site of them runing in a bone stock ls and it runs like a top.but they are 250$ for each injector..... got a pay to play.
ps if you want to sell your id 1000s for a good price id be intrested.
alex
alex
I made a little over 600 whp on ID1000s, 100 base fuel pressure, with a walboro feeding a bosch044. That was pretty much maxing out the injectors. This was on e85..
The 2000cc are big injectors regardless , we want something in between for us sub 700whp guys ""hint 1500cc
It's not quite as simple as making something in between. If the 1000's at high pressure will not get you where you need to go (which they won't with that turbo and E85), then step up to the ID2000's. They are just as streetable as a typical 1000-1200cc injector and MILES better than the Bosch 1600's we used to run.
do you have any pics of your surge setup Im looking for ideas for mine that I want to run
There are a few EVO guys making over 850whp on E85 with the ID2000's and have room to go. The ID2000's at 3 bar fuel pressure, on E85, should be good for close to 1000hp at 9k rpm.
The HP calculator here should tell you everything you need to know. An average BSFC for E85 is around .750.
http://www.injectordynamics.com/hors...alculator.html
