max psi vs 440 inj.
Old Aug 9, 2011 | 02:45 PM
uscivicmc's Avatar
Default max psi vs 440 inj.
maybe a stupid question but i've got precision 440 injectors in my stock ls/v with head studs and rod bolts. right now i'm running 8psi, if i turn it up, whats the max, so to speak, i can run one these injectors? all i want is a round about.
Old Aug 9, 2011 | 03:43 PM
92frostwhtdb2's Avatar
Default Re: max psi vs 440 inj.
Psi is means nothing...around 300whp
Old Aug 9, 2011 | 03:49 PM
joppe's Avatar
I runned 19psi with RDX injectors and 60psi base pressure. d16z6 and hy35 turbo. Maxxed out but afr was steady.
Old Aug 10, 2011 | 05:07 AM
CDecker0218's Avatar
close to 300whp.
Old Aug 10, 2011 | 07:06 AM
Turbo-LS's Avatar
Depends on base fuel pressure how much HP you can get out of any injector but yeah 440's are usually good to around 300whp, they can be pushed further if you have a fuel pump to support higher pressures
Old Aug 10, 2011 | 01:43 PM
uscivicmc's Avatar
we'll i've got a walboro 255 and have access to a fpr so we'll see
Old Aug 11, 2011 | 09:33 PM
W!d3b0dYr3X's Avatar
Fuel pressure will only go so far as well. If you max out the injector duty cycle get ready for a rebuild. When it comes to injectors, if in doubt go biggger. No one likes melted pistons and blown motors.
Old Aug 12, 2011 | 12:43 AM
rich7777's Avatar
Wise words...
Old Aug 14, 2011 | 09:11 AM
EsotericImage's Avatar
Retired Moderator
Eric,
I see you posting in here.. you know that the injector cycle is not to exceed 85% which will be the work of your tuner to get the most squeeze out of the 440s.
see you on the other side buddy
SpeedRacerEX-R
Jul 29, 2015 08:26 AM
wantboost
Feb 10, 2013 08:33 PM
s.cha
Jul 10, 2010 11:29 PM
graphic
Apr 7, 2004 11:42 AM
7rrivera7
Aug 21, 2003 10:07 AM
