I see smoke sometimes??????? Help
Old Sep 10, 2008 | 05:22 AM
Boostinb20!'s Avatar
Default I see smoke sometimes??????? Help
Ok I got my car going again after a minor head gasket replacement, but prior my car was smoking not alot but here and there. Keep in mind it was running pig rich prior to dyno as well. anyways i a mrunning a B20 vtec turbo motor presicion turbo 500whp, if i idle for a period of time then drive off it will smoke for just a bit and go away while crusing. now while just driving there is not smoke the times i see it is if i deccelerate on the highway and let the car slow down and tap the throttle i see alot of smoke. i also see smoke under boost but just for a bit as well any ideas im not sure if im just burning all the crap in the exhaust from running rich for so long. Leak down test show great across the board and compression as well.
Old Sep 10, 2008 | 06:09 AM
Default Re: I see smoke sometimes??????? Help (Boostinb20!)
some seem to this it is valve guides but i had the head check out when i pulled it off to replace the head gasket and it was perfect. maybe wash down in the cylynders from too much fuel
Old Sep 10, 2008 | 09:46 AM
tagperformance's Avatar
smoking on deceleration sounds like valve seals need to be replaced, also you could of washed the cylinders also form running the car too rich. you might want to check the oil seal on the turbo that can be bad also if you don't have some kind of pressure restrictor for the oil going from the engine to the top of the turbo.
Old Sep 10, 2008 | 10:03 AM
Default Re: (tagperformance)
I just got the Turbo back from precision they told me that my last turbo failed due to oil starvation and said not to run a restrictor, also if the valve guides were bad would that show up when they bench flowed and tested the Head?
Old Sep 10, 2008 | 10:07 AM
valve seals not valve guides.
Old Sep 10, 2008 | 10:09 AM
never replace a set on a b series motor the head have to come off to replace them i assume they do.
Old Sep 13, 2008 | 12:39 PM
Vtak DOHCTA's Avatar
usually when a turbo car smokes on decel, something is wrong with the turbo....check your drain make sure it is angled properly and is the right size....rule of thumb is a 5/8, 1/2" minimum
Old Sep 13, 2008 | 12:43 PM
SovXietday's Avatar
Default Re: (Vtak DOHCTA)
Blown turbo seals.
Old Sep 16, 2008 | 06:35 AM
Default Re: (SovXietday)
The turbo is brand new Bro
nengx07
Jun 1, 2010 08:50 AM
kingstonef
12
Oct 30, 2009 06:39 PM
Boostinb20!
Sep 10, 2008 01:11 PM
Mikeman191
Jun 23, 2003 02:24 PM
Qwikrex
Apr 29, 2002 06:03 PM
