Valve Seals????????
Old Sep 10, 2008 | 11:37 AM
Boostinb20!'s Avatar
Default Valve Seals????????
Ok I got my car going again after a minor head gasket replacement, but prior my car was smoking not alot but here and there. Keep in mind it was running pig rich prior to dyno as well. anyways i a mrunning a B20 vtec turbo motor presicion turbo 500whp, if i idle for a period of time then drive off it will smoke for just a bit and go away while crusing. now while just driving there is not smoke the times i see it is if i deccelerate on the highway and let the car slow down and tap the throttle i see alot of smoke. i also see smoke under boost but just for a bit as well any ideas im not sure if im just burning all the crap in the exhaust from running rich for so long. Leak down test show great across the board and compression as well.
Old Sep 10, 2008 | 11:56 AM
Drifterxs12's Avatar
Default Re: Valve Seals???????? (Boostinb20!)
yup. sounds exactly like valve seals to me
The high vacuum at idle and during deceleration is pulling oil down through the bad seals.
Old Sep 10, 2008 | 01:11 PM
Default Re: Valve Seals???????? (Drifterxs12)
But even as your starting to go under boost? i think this is what it is but i thought i was get some opinions. thanks
iperez
Jul 5, 2024 03:58 PM
Boostinb20!
Sep 16, 2008 06:35 AM
bigempty12
Mar 11, 2008 07:01 AM
Layziebtnh055
11
Apr 21, 2004 03:24 PM
FAST94GSR
Dec 15, 2001 05:07 PM
