I need someone elses input
Old Nov 15, 2011 | 07:31 PM
notsolfast's Avatar
Default I need someone elses input
Okay, I have a del sol with a jdm b16 in it. Stock internals, nothing done to it. I was able to pick up a Turbo fairly cheap so i did. I researched into piecing a kit together and this is what I have
-turbonetics t3 Turbo .57 trim I believe (57 stamped on cold side)
-deltagate external wastegate with manual boost controller
-vortec blow off valve
-dsm 450cc injectors
-walbro 255 (of course)
-intercooler, pipes and all oil lines.
Ill be having it tuned on chrome with a chipped ecu by innovative tuning. Would all of these work well with each other? Or should i change some parts while i still can. I have all winter. Thanks in advance
Old Nov 15, 2011 | 08:03 PM
SiRCiviC94's Avatar
Default Re: I need someone elses input
sounds just fine, get some pics of what you have im intersted in the pipes.
id rec. a flex in the dp and a wideband and colder plugs but your tuner will know. what power goal ?
Old Nov 15, 2011 | 08:11 PM
notsolfast's Avatar
Ill post some pics tomorrow. I have a flex pipe in the dp, but I'm going to just have the exhaust out the fender. I'm hoping to get about 275whp. Plenty for the street.
Old Nov 15, 2011 | 08:37 PM
jdmcivic2fast's Avatar
that should work well for 275 horsey's, i have a similar turbo (garrett 57 trim) on a stock internal LSV pushing just 8 psi im making 300/230 @ the wheels in my 95 civic hatchback, very fun to drive, this thing takes out Camaro SS and Cobra's on highway all day!!
Old Nov 15, 2011 | 08:47 PM
mikesrex's Avatar
might want to throw in some ARP headstuds
Old Nov 16, 2011 | 06:40 AM
notsolfast's Avatar
Why should I upgrade my head studs?
Old Nov 16, 2011 | 07:23 AM
kbouchard1092's Avatar
Cause OEM headstuds cannot be torque as tight as a ARP stud, and there simply not as strong. Under boost the head will lift causing Headgasket like issues. Do not run OEM head studs
Old Nov 16, 2011 | 07:27 AM
TheShodan's Avatar
Moderator
You can run the OEM ones fine as long as your power goals are reasonable. Until I built my engine, I was running a BONE STOCK head for over 7 years. Its all in your tune. If you plan on changing anything in the head which requires removal, only then would I change headstuds to ARP.
Old Nov 16, 2011 | 08:23 AM
notsolfast's Avatar
Do you think my power goal is too high for a stock b16?
Old Nov 16, 2011 | 08:30 AM
No...but i think you should do ARP headstuds for piece of mind...that is a common issue. I agree if youre not taking the head off though then you probably dont need too until it becomes a issue, But it could save you a headache if you just do it now
Old Nov 16, 2011 | 08:33 AM
notsolfast's Avatar
Well the engine has about 40k on it and the body has 17k original on it. I'm changing the timing belt and water pump over winter. And the clutch too. And brakes. And paint haha I hope it'll be strong enough for a turbo
Old Nov 16, 2011 | 08:42 AM
SiRCiviC94's Avatar
if you like wrenching just do the head studs, and inspect the head for wear
postman
Jan 6, 2011 07:41 AM
Honda4life777
Jul 17, 2009 06:13 PM
redsolturbo
Mar 24, 2006 12:40 AM
hialeahzbg
Jan 23, 2006 08:59 PM
DigitalFusion
Jul 4, 2004 12:34 AM
