Installing Turbo: What are the most commonly forgot items to have?
Hey all,
I all the parts, either coming in the mail, have already, or know I need to order, for my turbo setup. As we all know too well, there is always a million little "something"s we end up running up to the hardware store to get. I figured I would post this here and perhaps some people will toss in the things they forgot to get ahead of time.
*=Have or on its way
RevHard Mani *
RevHard DP *
Exhaust Gasket *
T3 Ford Turbo with reman'd Center *
Manchined Flanges to connect goofy ford compressor *
Mushroom Air Filter *
Tial 35mm WG *
Wastegate Elbow *
30x9x2.5 FMIC *
2.25 IC piping and all connectors/clamps *
TurboXS RFL BOV *
Oil Feed Kit *
Vacumme Manifold *
Walbro 255 In Tank *
RC550's *
Willem Enhanced Programmer *
Zif Socketed ECU *
Manual Boost Controller *
Boost Gauge *
Wastegate Dumptube
Mani/Turbo Stud Kit
Turbp/DP Stud Kit
27C256 Chips
Vacumme Lines
Oil Return Kit
WG to Turbo Stainless Line
NGK BKR7E11 Plugs
Flex pipe to connect DP to Exhaust
So, what am I forgetting? What did you forget?
RevHard Mani *
RevHard DP *
Exhaust Gasket *
Tial 35mm WG *
Wastegate Elbow *
30x9x2.5 FMIC *
TurboXS RFL BOV *
Oil Feed Kit *
Vacumme Manifold *
RC550's *
Zif Socketed ECU *
Boost Gauge *
Wastegate Dumptube
Mani/Turbo Stud Kit
Turbp/DP Stud Kit
27C256 Chips
Vacumme Lines
Oil Return Kit
NGK BKR7E11 Plugs
Re: Installing Turbo: What are the most commonly forgot items to have? (DigitalFusion)
always use a new oil pan gasket, extra clamps. and teflon tape.
edit- also bolts for your wastegate elbow/ wastegate.
zip ties. screws. nuts. bolts
Modified by project dc2 at 1:47 AM 7/3/2004
Re: Installing Turbo: What are the most commonly forgot items to have? (project dc2)
nice! I completely forgot about the oil pan gasket! I have plenty of teflon tape, and extra clamps.
DiRep (Chris) and Art will tell you to have plenty of Mountain Dew.
Id suggest taking your time AND take pics for us!
Re: (DigitalFusion)
running open wastegate? you will ne a dump tube unless you want the exhaust to go right back into your motor when it opens up
Re: (tegsedan)
Wastegate dumptube is already in that list. I already have a couple of gallons of amsoil and oil filters that I just keep on hand, so I didnt include those in the list
Re: (DigitalFusion)
Unless your planning on hitting up the exhaust shop your definately going to need a welder. For obviously the flexpipe but something a lot of people forget is that they need to tap into the oil pan, and weld the oil line there. Don't use jbweld for that, definately get a quality weld job.
A tester to check for vacuum leaks. A buddy of mine made something from home depot and we used a compressor and checked for leaks up to 10psi and we found 3-4 leaks, saved me a huge hassle of trying to find them just by guessing. Make sure all the clamps, fittings are tight as possible. Those stud kits you got, make sure those damn bolts are tight, they have a very high tendancy of coming loose.
Have a car ready to go for any store runs. Bceause trust me, no matter how prepared you are, there will be something that you forget. Or something that you need to exchange and swap. Grab some locktite, locktite washers for the wastegate/manifold....i've had mine come loose on me twice, until i finally did it right. The gaskets for those suck, so you don't really need to even use one, just make sure the **** is tight and check it frequently.
a ton of tools, a few buddies to keep you company and help out....then have a few beers lined up for the finish and then take some pics
Guest
Posts: n/a
Re: (patdemps)
Here's some stuff that some people may overlook..and end up going to the store to get.
Teflon Tape.
Replacement manifold flange nuts.
Tap/Die set(Optional but very handy)
Anti-Seize lubricant
Tee fittings for vaccum lines
Drill, misc. bit sizes, screws nuts and bolts, wire ties
Threadlocker
Solder gun/solder, extra wire.
3 feet of radiator hose for oil return line
Saw for cutting splash guards
HIGH TEMPERATURE GASKET MAKER.
Common sense.
And a camera so you can show everyone how much an idiot you are. Just kidding.
Modified by illicon2003 at 12:40 PM 7/5/2004
Teflon Tape.
Threadlocker
Common sense.
-You might need to buy some slim fans.
-A dremel is super useful, definately need it to notch your block.
-Plugs and nipples for the vac. manifold.
-Gauge pod and more gauges.
-Wideband.
-Larger exhaust?
-You might want to install the parts you can as you go along. That way if you start having problems you know what you did wrong, instead of having to troubleshoot through the entire install.
-Wideband.
-Larger exhaust?
Tru Dynamix
03-02-2003 09:41 PM
