New Fuel Lab Mini Fuel Pressure Regulators
Fuel lab has come out with their new Mini regulators. They are much smaller then a traditional fpr. They only weigh 5.25 oz. as opposed to 12 oz. for their regular sized ones. What I really like about these fpr is the ability to mount them on the fuel rail. With their size and light weight design they don't look awkward mounted on the fuel rail like their regular sized fpr.
They come in two different pressure ranges also. A 25psi-90 psi range and a 90-125psi range. These ranges represent the base pressure adjust ability. So if your running a walbro intank pump in conjunction with bosch 044 inline and ID1000cc injectors. You will need a high base pressure (90+psi base)to get the most out of the fuel setup. So you would use the fpr with the 90-125psi range.
If your running just a walbro intank then the 25-90psi one would fit nicely.
Another plus to mounting it to the fuel rail is you only need one line as opposed to two lines.
Re: New Fuel Lab Mini Fuel Pressure Regulators
Not that I would ever want to mount one of those regulators on my rail, but make sure people know to use a STEEL fitting if they even consider doing this.. The last thing we need are peoples cars catching fire when the vibration from the motor causes the regulator to break off..
They make them with -10 inlets and -6 inlets. The outlet is a -6. The ones we have in stock are -6 inlets.
Yes please use a steel fitting when attaching the regulator to the fuel rail. Our kits come with a steel fitting.
They do have purple as an option for color.
Here's what the kits look like. We're just waiting on the steel o-ring boss fitting which is not pictured. I should have them in stock on Thursday.
Also if you want to get rid of your stock fuel filter. We have a kit for that to.
Are these a pretty good selling item? Do you have a kit that contains all the fuel line and fittings to mate up with a specific brand name fuel rail such an aem rail or edelbrock rail, golden eagle etc etc?
Will the fuel filters also survive when using very high base pressures? What are the elements made of and where can replacements be bought?
Are the Reg's Ethanol Compatible? Filters?
If your running methanol or alcohol then you will need stainless steel elements only. We carry those in a 100 micron and 40 micron element.
The kit comes with:
10 micron fuel filter with o-ring boss fittings
billet aluminum fuel filter bracket
hard line adapter
3 -6 straight hose ends
1 -6 90 degree hose end
3 ft. of ss hose or black pro lite hose
o-ring boss fitting for fuel rail (such as, GE, BDL, AEM, etc)
Yes we do have a kit that includes everything needed to go from the stock hard line to the fuel rail.
The kit comes with:
hard line adapter
The kit comes with:
hard line adapter
HELLO,GOOD MORNIN'
keep the thread as a new item thread. refer to the Marketplace -forum for pricing. aske tech questions in here please
