i need a base map
Old Apr 18, 2007 | 02:39 PM
zenon8890's Avatar
Default i need a base map
hi HT, i need a base map for a sohc vtec on OBD0 pr3 plz, urgent
its stock engine and stock injectors
thanks u
Old Apr 18, 2007 | 02:55 PM
nonvtecD's Avatar
You left out what engine management you're using, which dictates the basemap. If it's stock then run the stock ecu...
Old Apr 18, 2007 | 03:02 PM
zenon8890's Avatar
thanks for trying to help, i have only a pr3 ecu and its tunned for 450cc injectors, i dont have the injectors at the moment so the engine bogs like hell, i'm using BRE and i dont know how to make my own base map. i have a boosted d15b vtec
Old Apr 18, 2007 | 08:05 PM
nonvtecD's Avatar
Can't you just disable the chip in your ecu and run the stock map? Why do you have stock injectors if you're boosted? Why do you have a map for 450's? I'm not trying to be rude, I'm just confused.
Old Apr 19, 2007 | 04:34 AM
zenon8890's Avatar
yes i can disable the chip, but the pr3 is meant for b16a engine and will run rich on my d15b, i lost the injectors in the mail, so i'm stuck on the stock injectors, plz if anyone has a BRE sohc vtec boosted map upload it or send it to my e-mail
zenon8890@hotmail.com
thanks
Old Apr 19, 2007 | 07:05 AM
fastcrxsi90's Avatar
From: the asshole of america..., upstate new york, USA
Default Re: (zenon8890)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zenon8890 &raquo;</TD></TR><TR><TD CLASS="quote">hi HT, i need a base map for a sohc vtec on OBD0 pr3 plz, urgent
thanks u</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zenon8890 &raquo;</TD></TR><TR><TD CLASS="quote">yes i can disable the chip, but the pr3 is meant for b16a engine and will run rich on my d15b, i lost the injectors in the mail, so i'm stuck on the stock injectors, plz if anyone has a BRE sohc vtec boosted map upload it or send it to my e-mail</TD></TR></TABLE>
so what are you looking for? a stock (na) d15b map, or a boosted d15b with stock injectors map?
if your temporarily running na with stock injectors just use the stock pr3 map...it should be close enough and run fine in closed loop (i would think)...
Old Apr 19, 2007 | 07:21 AM
nonvtecD's Avatar
A b16 map won't actually run that rich, especially if you have an o2 hooked up.
Old Apr 21, 2007 | 04:23 AM
zenon8890's Avatar
i want a boosted d15b vtec base map with stock injectors, i dont have any o2 sensors pluged in
Old Apr 21, 2007 | 03:15 PM
zenon8890's Avatar
bump
Old Apr 21, 2007 | 04:25 PM
EJ1 wilcox's Avatar
What's BRE?
Old Apr 21, 2007 | 04:45 PM
Jim Truett's Avatar
Default Re: (EJ1 wilcox)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ1 wilcox &raquo;</TD></TR><TR><TD CLASS="quote">What's BRE?
Ben's Rom Editor
Old Apr 23, 2007 | 12:34 PM
zenon8890's Avatar
bump
Old Apr 23, 2007 | 01:50 PM
inspyral's Avatar
What's the point of a "boosted basemap with stock injectors"? Wouldn't the injector duty cycle in the boost columns be way above 100% anyway? So couldn't you just run a stock map and just drive without going into boost?
Old Apr 25, 2007 | 02:56 AM
zenon8890's Avatar
Default Re: (inspyral)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by inspyral &raquo;</TD></TR><TR><TD CLASS="quote">So couldn't you just run a stock map and just drive without going into boost?</TD></TR></TABLE>
funny man
Old Apr 25, 2007 | 05:05 AM
depending on your setup, your going to max out those injectors maybe around 3-4psi-ish. you'll wish you had waited to get injectors...
i can post up a map for you, but its just going to be a shot in the dark. here is a tool to help you do it yourself...http://www.xenocron.com/downlo...apper. this should atleast get you running good in vacuum...stay out of boost (not being funny)
Old Apr 25, 2007 | 07:48 AM
zenon8890's Avatar
thank u for ur help, i contacted chris harris and he sent me the BIN file online for 450cc injectors on pr3 for sohc, if i changed the injector size in BRE, would it work?
Old Apr 25, 2007 | 01:14 PM
zenon8890's Avatar
bump
Old Apr 25, 2007 | 08:00 PM
nonvtecD's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zenon8890 &raquo;</TD></TR><TR><TD CLASS="quote">thank u for ur help, i contacted chris harris and he sent me the BIN file online for 450cc injectors on pr3 for sohc, if i changed the injector size in BRE, would it work?</TD></TR></TABLE>
You mean if you change the injector size and then burn a new chip? That's how it works in every obd1 editor I've used so I don't see why it would be different in BRE.
Fnix
May 17, 2012 03:04 PM
timisyourfriend
10
Jan 6, 2006 07:31 AM
IntegracinGSR
Jan 11, 2004 01:27 PM
ion_four
Jul 8, 2002 10:49 AM
