i got problemss!!!
Old Jun 24, 2009 | 04:39 PM
turboek97's Avatar
Default i got problemss!!!
whats up hondatec,
soo i have this problem ive been trying to fix forever with my ls turbo civic....when im boosting at a low rpm 5th gear for example (under a load) the boost gauge jumps all over the place and it sounds like the wastegate is opening and closing like a flutter or boost creep...i smoke tested it and there isnt any vacuum leaks the w/g is new the bov is new..idk wtf is goin on with it....also my brake pedal goes to the floor once a few mins after i start the car and then is fine for the time i drive it? i just put new rotors and pads on and bled all 4? ive ran out of ideas somebody please help me with this pos! the car is a 97 ek coupe dx and the rear brakes are ls rear discs
i made a video to help diagnose but i cant seem to attach it i can send it from my cell but im going to try to make another
Old Jun 24, 2009 | 05:10 PM
-16V-'s Avatar
Default Re: i got problemss!!!
Put the video on youtube then reply with the link.
Thats what i do.
Old Jun 24, 2009 | 06:14 PM
turboek97's Avatar
<embed width="448" height="361" type="application/x-shockwave-flash" wmode="transparent" src="http://i697.photobucket.com/player.swf?file=http://vid697.photobucket.com/albums/vv340/highallthetime76/wtfffff.flv">
Old Jun 24, 2009 | 06:16 PM
turboek97's Avatar
http://s697.photobucket.com/albums/v...nt=wtfffff.flv
heres the linkk i uploaded it to photo bucket
Old Jun 24, 2009 | 06:17 PM
turboek97's Avatar
i was thinking it may be a bad brake booster? maybe a bad proportioning valve with the brakes? idk man this car has me running in circles
Old Jun 24, 2009 | 06:19 PM
aleks77's Avatar
I had similar problem with the brakes, for me it was my brake master cylinder.
Old Jun 24, 2009 | 09:12 PM
turboek97's Avatar
i was thinking it was the master also..but i bled the brakes and the pedal feels great...with the car off but as soon the car is on the pedal is very spongey and feels like sh*t
Old Jun 24, 2009 | 09:13 PM
turboek97's Avatar
i was thinking that maybe the boost problem was related to the brakes but i have no idea
Old Jun 25, 2009 | 04:36 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
When you press on the brake pedal does air bubbles come out of the master cylinder into the fluid?
Old Jun 25, 2009 | 04:41 AM
00si2's Avatar
All that's happening is the boost controller is allowing the wastegate to open at whatever psi you have it set at and the gauge is fluttering. I'm guessing that's a mechanical boost gauge you have?
What are you using for a boost controller?
Old Jun 25, 2009 | 06:30 AM
turboek97's Avatar
I don't have a boost controller I a synapse engineering w/g's where u can control the boost with how the vacuum lines are hooked to it
Old Sep 27, 2009 | 12:24 PM
turboek97's Avatar
finally i find the cause of this problem!!!...........my freakin air filter i had on the turbo was causing this....i guess it was restircting air flow..but since i have removed it theyre is no fluttlering
Old Sep 27, 2009 | 01:05 PM
Kr4nG's Avatar
what do you mean by the air filter. was it clogged?
Old Sep 27, 2009 | 01:09 PM
ME=ADRIAN's Avatar
and if yur brake pedal is goin to the floor thats a seperate problem like they said..internal leak in the mc
PNK SLP
Feb 21, 2011 09:56 PM
Syndacate
17
May 11, 2010 08:20 PM
95civ
Aug 19, 2005 06:05 AM
eg6T
Oct 1, 2004 06:14 PM
pelotudo
Sep 25, 2002 01:12 PM
