I can't figure out what is causing the while smoke
Old May 11, 2009 | 03:11 PM
dc2doi's Avatar
Default I can't figure out what is causing the while smoke
I got a b16 turbo
Its running on 100 octane
Engine has good compression 155 all around.
No coolant in oil and no oil in coolant.
Spark plugs are dark, extremely rich from 100 octane untune.
Car is untune. p28 ecu with a hondata s200.
I want to figure out what the hell is this white smoke before I tune the car.
Turbo seems fine, little to no shaft play at all.
I get a gust of white smoke. cloud up the whole street kind of thing.
Can't seem to figure it out, Any ideas guys?
Old May 11, 2009 | 03:28 PM
mpf90's Avatar
Default Re: I can't figure out what is causing the while smoke
ha I got the same smoking problem. I changed my hg, piston rings and rebuilt the turbo but its still smoking. I was told my oil line needs to be restricted, im on vacation right now but ill let you know how it goes when I get back.
Good luck with it, if you figure out what it is lemme know.
Old May 11, 2009 | 07:32 PM
smoovy's Avatar
I've had this issue before. check your oil return or you could have crankcase ventalation problem too. take off your downpipe and look at it. if you see oil in there and I mean caked in there, then oil is leaking past your seals and the oil drain should be addressed.
Old May 11, 2009 | 11:55 PM
ITR.#1446's Avatar
Originally Posted by dc2doi
I got a b16 turbo
compression test wont tell you much you need to do a leakdown..... also running 100 octane isn't really gonna make you more rich then 93, what is your setup and injector size?
are your spark plugs dry dark or wettish dark?
http://www.verrill.com/moto/sellingg...colorchart.htm
Old May 12, 2009 | 07:02 AM
th3pwn3r's Avatar
I have the same issue with my B16 but it's only noticeable around 4,000 to 4,500 RPM and then it gets bad. I've been told my engine is "fuel washed" where the cylinders are now glazed with fuel from running a rich mixture. I've also been told that it could be the valve seals on the head.
Old May 12, 2009 | 07:14 AM
cpl rampage's Avatar
when does it blow smoke? white smoke is generally coolant, and your description furthers that because its actually steam and tends to billow alot.
Old May 12, 2009 | 11:09 AM
dc2doi's Avatar
From the chart it looks like a carbon fouled plugs. Seems really rich. The smoke would start probably 30 seconds into the start up.
injectors are dsm bluetop 440cc.
Old May 14, 2009 | 03:47 PM
dc2doi's Avatar
I replaced the PCV valve today. Old one was full of oil. Still smoke alot.
What ive noticed is it smokes when the engine is warm. Any idea guys?
Old May 14, 2009 | 07:10 PM
EARLdaSQUIRREL's Avatar
official honda whore
valve seals??/
do a leakdown test
Old May 14, 2009 | 08:18 PM
mpf90's Avatar
Valve seales would be worse right when you start up the motor. I looked around and your compression seems kinda low compaired to what I found on a couple sites but I couldn't find a deffinate number of what it should be. Did you do a wet test with it??
If the pcv is working off vaccum opening it, wont it stay closed if you have a turbo??
x3 leakdown test
Old May 15, 2009 | 11:48 AM
dc2doi's Avatar
I dont have a leakdown tester.
Valve stem seals are basically brand new, probably have 20 miles on them. Replaced it when I put in a thicker headgasket to lower the compression.
Pistons are dry as hell. Car is going in for a tune today, maybe its the high octane?
Its running 100 octane on a p28 untune.
daboy155
Oct 9, 2015 07:01 PM
cooltron
Mar 28, 2008 01:54 AM
big-cat
Jun 21, 2007 06:09 AM
NateTEG95
Oct 7, 2003 03:20 PM
sushibug
May 29, 2002 03:52 PM
