how-to tap the oil feed line on a greddy kit off the block?
how do i go about getting the stock fitting out of the block? it seems it is covered with a rubber cover (d16y7 block), anyone have tips? i dont wanna mess it up
Re: how-to tap the oil feed line on a greddy kit off the block? (Civiclx)
Are you referring to the oil pressure sending unit?
The rubber cover is just part of the wire, it should pop off. Then you need a 24mm deep socket to get it out.
1 Post
Re: how-to tap the oil feed line on a greddy kit off the block? (beepy)
i had to use a vice grip to grap the hole thing, rubber boot and all. i ended up tearing the boot a little bit but i didnt see any other way. once you loosen the bolt a bit i makes the boot come off easier. pm me with any other Q's im still working on oil lines on my greddy kit.
TAG
11-17-2003 11:13 AM
