How much WHP have you made with your greddy turbo kit?
Like it says. I am just about done with my Greddy turbo kit installation on a b18c1 hatch. Although I must say I am worried about what I will be making whp wise. I am completely stock except for 2 1/4 exhaust, high flow cat, and a 255lph fuel pump. Also I will be running uberdata for the setup. My goal is 220-230 whp with 7psi on my stock block and head. Is this possible or have I made a huge mistake with going with the greddy kit? So what were your experiences? Like setup and whp? Thanks, I also plan on dyno tuning with uberdata, but cannot take the suspense to find out what I will make.
Re: How much WHP have you made with your greddy turbo kit? (norcalcrx)
yea the motor only has like 60k, we did a compression test and it was perfect in all 4. I just read a thread on here with a kid who only made 197whp with the bluw box, although I am using uberdata, and will be dyno tuning it. I boosted today for the first time on the stock ecu and it was very strong. With only about 1/2 throttle in 2nd the tires were breaking loose alittle. Hopefull with uberdata and tuning I will be around 230 at the wheels. That is my goal. Thanks everyone for responding.
Re: How much WHP have you made with your greddy turbo kit? (st00pid)
http://www.boosted-hybrid.com/viewtopic.php?t=28
http://www.boosted-hybrid.com/viewtopic.php?t=86
tune conservatively and choking
Re: How much WHP have you made with your greddy turbo kit? (roydogg)
My numbers with the greddy kit are weak, but I'm just using the Blue Box, it's not tuned at all. Numbers in sig.
Re: How much WHP have you made with your greddy turbo kit? (xPRELUDEx)
I am shooting for 300 or so WHP from my 1.8 this spring.
with absolutly zero tuning and a AFC @11psi with lowered compression I did 230whp and 192wtq(My AF was in the high 9:1 range for almost all of vtec. you should make that power pretty easily on a tuned car
stock b18c1 except for a thicker head gasket, and a s-afc too tune the blue box with i made 298 whp on a 60k mile motor @12 psi. oh ya i had a block gard too.
Re: How much WHP have you made with your greddy turbo kit? (BoostedITR41)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedITR41 »</TD></TR><TR><TD CLASS="quote">I am shooting for 300 or so WHP from my 1.8 this spring.
with absolutly zero tuning and a AFC @11psi with lowered compression I did 230whp and 192wtq(My AF was in the high 9:1 range for almost all of vtec. you should make that power pretty easily on a tuned car</TD></TR></TABLE>
wow, I'm looking for 300whp from my 18g kit on my itr too!
I sent you an IM, cause our setups sound similar.....
Re: How much WHP have you made with your greddy turbo kit? (Black R)
300 with a greddy kit shouldn't be a problem just gotta piece the parts out correctly such as IM,3.0" exhaust, dp, cams, and boost controller.
99_red_si
02-22-2008 05:21 PM
-BlueGSR-
04-24-2003 09:52 AM
