how much spray?????
Old Nov 13, 2011 | 03:45 PM
STAKEN's Avatar
Default how much spray?????
I have a sleeved 84mm 14.1 comp. lsvtec and i want to know how much spray can i safeley get away with. its fully built.
Old Nov 13, 2011 | 04:28 PM
STAKEN's Avatar
Default Re: how much spray?????
IF YOU READ IT AT LEAST BUMP ME PLEASE I NEED SOME INFO
Old Nov 13, 2011 | 07:24 PM
MShonda's Avatar
You should ask your question in the Official Nitrous Thread
Old Nov 13, 2011 | 07:47 PM
bauergold's Avatar
That really depends on the setup and how much you know about tuning nitrous setups.
In the right hands, that setup could make a lot of power on nitrous.
Old Nov 14, 2011 | 07:53 AM
kbouchard1092's Avatar
there is really no definate answer... It all comes down to youre tuning and what kind of management you run to control the nitrous/Fuel.
I only run a 35shot but that is with a turbo car so its a different scenario. i have mine controlled by the hondata S300 which is just a dry shot but fuel is increased thru injectors ( which is essence is a wet shot)...This is a much better way to control fuel and timing then youre basic dry shot kit,and even some wet kits. Since you can really dial in fuel and timing more percisly
That being said i would say you could run 200 shot with a nice direct port setup and a real good management system and tune.... Its really comes down to youre goals, and of course youre budget... How much power do you want?
Old Nov 14, 2011 | 09:39 AM
ugly88si's Avatar
run a big injector and 100 dry.on the right cam and tune you should see just over 400.if youve got sleeves pistons and rods and a good balance it should last a while
Old Nov 14, 2011 | 11:48 AM
You will not get 400whp on a 100 shot on a N/A application
Old Nov 14, 2011 | 12:16 PM
sanman000719's Avatar
as much as it takes to get the flee's off the dog man
Old Nov 14, 2011 | 05:35 PM
STAKEN's Avatar
well im runing the aem stand alone system, 1000cc injectors on e85,my cams are skunk2 pro3 with itb's.im building the motor hoping for 260whp plus a little juice im wanting to get a plate fogger system.well keep on with the help
bluenc-87
Engine Management and Tuning
11
Sep 29, 2015 08:34 PM
DA-MAX
Jul 13, 2005 01:59 AM
PolyPill
Dec 15, 2004 01:48 PM
B18C1CYA
Jul 28, 2004 11:53 AM
-Racer X-
Jun 8, 2003 11:41 PM
