ITBs and direct port nitrous
Old Dec 10, 2004 | 05:09 AM
DA-MAX's Avatar
Default ITBs and direct port nitrous
I'm redoing my current setup and adding CBR 929 throttle bodies...the motor is a b18b the major components are 80 shot direct port, crower 403s and 11:1cr. now my plan was to run my fuel injectors in the CBR injector holes in the ITB and then re-install my nitrous nossles in the newly fabricated intake runners...my concern in this setup is, would there be any major problems having the nitrous/fuel nossles AFTER the fuel injectors??? I'm thinking no, since it is a direct port setup and fuel is dispensed with the nitrous....so its not like there is more dry nitrous being shot into the cylinders before the fuel, but any pointers?? seems like it might be a tuning nightmare though also would it matter the position of the nitrous nossles being closer to the injectors and ITBs or closer to the head?
I searched and found an old thread on here, but it was pretty short and the pic wasn't clear and I'm not sure whos car it was. thanks for any help
Old Dec 11, 2004 | 02:01 PM
ELAMINT5's Avatar
Default Re: ITBs and direct port nitrous (DA-MAX)
free bump...cause I would like to read the answer to this
Old Dec 11, 2004 | 02:07 PM
atcrx's Avatar
Default Re: ITBs and direct port nitrous (ELAMINT5)
no i do not think so. Got a buddy with a mustang an the nozzles are after the injectors. NO problems at all.
Old Dec 11, 2004 | 03:38 PM
DA-MAX's Avatar
thanks guys for bump and the response...if anyone else has any input, throw it in
Old Dec 11, 2004 | 04:02 PM
b00sted93Hatch's Avatar
Default Re: (DA-MAX)
I was thinking about doing a direct port on my itbs also. I was thinking about fabrication some brackets and have the noozle in front of the horns rather then tapping it into the manifold.
Old May 2, 2005 | 11:40 PM
#1151's Avatar
Default Re: (b00sted93Hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b00sted93Hatch &raquo;</TD></TR><TR><TD CLASS="quote">I was thinking about doing a direct port on my itbs also. I was thinking about fabrication some brackets and have the noozle in front of the horns rather then tapping it into the manifold. </TD></TR></TABLE> mount them on the firewall, and have the jets right in front
Old May 3, 2005 | 12:22 PM
visi0n's Avatar
Default Re: (TodaFiend)
been there...done that...
Old May 5, 2005 | 06:05 PM
minimesleeper94's Avatar
installing the nitrous before the fuel injectors will help atomize the fuel better.
Old May 5, 2005 | 07:05 PM
sohc steve's Avatar
Default Re: (minimesleeper94)
I've read a lot about putting the jets as far away from the cylinders as possible because the nitrous cools down the intake air alot=extra power, and yes, it does seem like it would help the fuel mixture atomize better. My 2cents.
Old May 6, 2005 | 04:34 AM
91civicDXdude's Avatar
i've seen pictures of ITB setups that have the fogger nozzles mounted so that they spray into the end of the velocity stacks, although i dont know how efficient that would be
Old Jul 13, 2005 | 01:39 AM
RIP V8s's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TodaFiend &raquo;</TD></TR><TR><TD CLASS="quote"> mount them on the firewall, and have the jets right in front </TD></TR></TABLE>
hahahah ig ot a budddy that did that......incogneto as all hell, " i swear its all motor"
Old Jul 13, 2005 | 01:59 AM
WickedSol's Avatar
Default Re: (91civicDXdude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by minimesleeper94 &raquo;</TD></TR><TR><TD CLASS="quote">installing the nitrous before the fuel injectors will help atomize the fuel better.</TD></TR></TABLE>
I agree! You should mount the nozzles on the Horns...
91integraLSVTEC
Sep 29, 2007 12:42 PM
invisible
Sep 11, 2007 03:53 AM
-Racer X-
Jun 8, 2003 11:41 PM
sPaRk'iT
Apr 24, 2003 11:52 AM
el arbi
Dec 2, 2002 01:05 PM
