Which Turbo?
Old Mar 19, 2004 | 03:19 PM
CiViC SiR's Avatar
Default Which Turbo?
hi guys,
which turbo do you guys recommend for a B16A Target hp is 500?
GARRETT T3/TO4E 60 TRIM W/ .82 A/R TURBINE
or GARRETT T3/60-1 W/ .82 A/R TURBINE
or GARRETT TO4S (T4/60-1) W/ .96 A/R TURBINE
Old Mar 19, 2004 | 03:23 PM
JdM_y0's Avatar
GARRETT T3/TO4E 60 TRIM W/ .82 A/R TURBINE seems promising
Old Mar 19, 2004 | 11:09 PM
M.A.R.C.'s Avatar
Default Re: (bluep3)
wow .82 a/r turbine? for 500whp? I'm pretty sure you could do it on a .63
Old Mar 19, 2004 | 11:11 PM
MiraiZ's Avatar
Default Re: (CivicRyda2k)
T4 might be too big for b16a, if this a daly driver, go for the top one
Old Mar 20, 2004 | 05:17 AM
TurboSedan's Avatar
New User
Default Re: (MiraiZ)
Yep, those last two turbos are huge on a B16A. The T3/T4 is fine although that .82 A/R turbine will cause it to spool a bit later than a .63 A/R which would be a better fit for your application.
BoostedSi
Apr 2, 2003 08:31 AM
Vu
Jan 26, 2002 01:01 AM
Ri5e
Aug 24, 2001 07:59 AM
