How much power can I expect out of my JDM ITR motor and a T25/T28 turbo?
Old 11-05-2003, 06:05 PM
jonnybravo's Avatar
Default How much power can I expect out of my JDM ITR motor and a T25/T28 turbo?
I am thinking of building a custom turbo setup that has full boost at 3500-4000rpm. Only planning for 8-10lbs of boost and would have a stock bottom end with Inline Pro headgasket to lower comression to about 10.3:1. Please let me know what you guys think.
Old 11-05-2003, 06:15 PM
Johnyquest's Avatar
Default Re: How much power can I expect out of my JDM ITR motor and a T25/T28 turbo? (jonnybravo)
You want a t3 60trim or bigger for an application like that.
If you want big power, go with an sc50.
If you want sick power, sc60 or 61.
You could easily get 300+whp, 400+ whp, and 5-700 hp with those setups respectively (with the correct internals / engine management /etc)
Old 11-05-2003, 06:19 PM
*Boostwerks*'s Avatar
Never put a T-25 on an ITR motor...You may end up with less HP overall than what it would N/A.
jonnybravo's Avatar
Default Re: How much power can I expect out of my JDM ITR motor and a T25/T28 turbo? (Johnyquest)
I'm really only looking for about 275-300hp. I don't drive this car on the strip. Only street and road courses so a quick spooling turbo is definitly a must.
Old 11-05-2003, 06:21 PM
jonnybravo's Avatar
Default Re: How much power can I expect out of my JDM ITR motor and a T25/T28 turbo? (Bryson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bryson &raquo;</TD></TR><TR><TD CLASS="quote">Never put a T-25 on an ITR motor...You may end up with less HP overall than what it would N/A.</TD></TR></TABLE>
Really. Isn't a T25/T28 the same as a T28 used on S15 motors?
Old 11-05-2003, 06:24 PM
Jkan2001's Avatar
The S15 DET motors use a T28 which are efficient to about 300 hp, the T25 is way too small and the T28 is borderline for the power numbers you want to achieve.
I'd suggest using a SC34 for quick spoolup and still 300whp easily. I have the SC50 on my d16 and it's good for up to 400-450 whp. If you want REALLY quick spool up i'd definetely suggest the .48 exhaust a/r.
Old 11-05-2003, 06:25 PM
jonnybravo's Avatar
Default Re: How much power can I expect out of my JDM ITR motor and a T25/T28 turbo? (Jkan2001)
I was considering the T28 also...
Old 11-05-2003, 06:34 PM
jonnybravo's Avatar
Or how would this be?
http://cgi.ebay.com/ebaymotors...35287
Old 11-20-2003, 09:43 AM
1990hondaHF's Avatar
I'd like to know as well...
Old 11-20-2003, 09:52 AM
TOO SMALL.
At least use a Straight T3.
Old 11-20-2003, 10:23 AM
Cyber ITR's Avatar
Default Re: (Bryson)
i used to run a t28 at 6psi on my jdm b18c , it makes just below 200whp , but it was enuf to help me getting 13.7 @ 113mph in a fucked up track in a crx tho
Old 11-20-2003, 10:40 AM
Boltz's Avatar
Default Re: (Day Walker)
putting a t25 on a ITR motor is like using a tornado on a ferrari... pointless
sc50 all the way
Old 11-21-2003, 08:51 PM
ERA
ERA's Avatar
Default Re: (FourceFed)
The T28 I am using on my LS hatch spools to a set 7psi at 3400... runs great, and I exactly what I wanted for street driving (daily) great power gains and nice to drive... eats WRX's, that's all I care about...
Old 11-21-2003, 09:30 PM
_Endless_'s Avatar
i'm using T-28 @ 7psi in my B16 and it didn't make more than 200whp. go with a straight T-3 instead.
Old 11-21-2003, 09:54 PM
E46M3CB's Avatar
Default Re: How much power can I expect out of my JDM ITR motor and a T25/T28 turbo? (_Endless_)
sorry for jacking this thread... but...
what numbers do u think i would yield for my mine?
Fmax turbo kit
t3/t4 turbonetics turbo
jdm itr motor 11:1 c/r leaving stock not gonna lower or change
440cc injectors, walbro 255lph, hondata s100b, aem frp & fuel rail
fidanza 7.5lb flywheel
planning to boost ONLY 6 psi
Well?
TIA
Old 11-22-2003, 02:32 AM
reaction360's Avatar
Default Re: How much power can I expect out of my JDM ITR motor and a T25/T28 turbo? (B18CDB8)
T3 .60/.48 turbo would be nice if you want quick spool. I had this turbo on my b16, and it spool extremely quick, full boost around 3500 rpms.
Old 11-22-2003, 04:34 AM
alpha's Avatar
That turbocharger isn't going to flow enough for your motor. You can rev that motor past 8,000rpm but you wont make power up there with a T25/T28. Go with a T3/T04E or an SC50. With your compression and displacement lag wont be a problem.
Old 11-22-2003, 04:43 AM
patdemps's Avatar
Default Re: How much power can I expect out of my JDM ITR motor and a T25/T28 turbo? (0x64)
Precision sc50
thats what I am going to use on my GSR. And my goals are 250-300whp tuned on 7psi. All custom kit.....so your right around where I want to be.
Old 11-22-2003, 02:38 PM
scooter's Avatar
Default Re: How much power can I expect out of my JDM ITR motor and a T25/T28 turbo? (patdemps)
I had a T3 on my stock ITR for a long time and it was awesome and cheap! Stock head gasket, stock bottom end and head.
This is 7psi. There was still much more in the setup. This dyno was done at a dyno day so I only got 3 pulls and no tuning.
10psi I made 280hp and 200tq, cant find that dyno graph at the moment..
scott
civicboy1128
05-22-2008 06:29 PM
keep_up
01-28-2008 04:40 AM
tonezilla
02-23-2004 11:34 PM
Atlas
02-17-2004 09:05 AM
mafioso102
01-14-2004 10:02 AM
Quick Reply: How much power can I expect out of my JDM ITR motor and a T25/T28 turbo?
