which turbo ?!?!?!
Old Feb 23, 2004 | 02:34 PM
tonezilla's Avatar
Default which turbo ?!?!?!
need to decide which turbo to get . its for an h23a1 and my goal is to get 250 whp . i am guessing the redline on the motor is 6500 . i want something as a daily and street driven car and maybe take it to the track 2-3 times a year . i want something to spool around 2.5 - 3k and make power all the way up to 6k .
i decided between these two turbos and cant figure out which one would be the best for me . after researching i found that the .48 spools quickly butt doesnt make power on the top end . butt the .63 doesnt make good low end butt makes up for it on the top end . i was originally going to go with the .48 butt i didnt know how much of a power difference i was loosing in the top end considering redline is like 6500 . please help me decide .
Old Feb 23, 2004 | 05:22 PM
tonezilla's Avatar
thanks for the replies . butt i was wondering if you guys could also leave a reason why you chose this turbo over the other turbo . or why i would want that turbo for my setup .
Modified by redxalien at 4:51 AM 2/24/2004
Old Feb 23, 2004 | 05:42 PM
beautifulblue's Avatar
Default Re: (redxalien)
go with the .48!! For 250 hp, u dont need that much flow that would require a .63. And for it being a street car, .48 will be more responsive.
Old Feb 23, 2004 | 11:34 PM
AspectIndustries's Avatar
Default Re: (beautifulblue)
For a longer rpm range on honda dohc vtec motors. I would go with the .63ar, since you will need stronger spools on top end. (We dont want to be losing power on top end now do we? ) t3to4e usually spools up pretty quick anyways. 2800rpm to 3200rpm range. Pretty much all it is , is the 1st gear you be waiting. then from 1st to 2nd to 3rd gear...its pretty much reved up high enough to be in full spooling. .63ar all the way!!
00pr3lude
Apr 4, 2008 06:09 PM
Del Campo92
Feb 15, 2006 09:50 PM
TrunkRattlin
10
Nov 7, 2005 10:35 AM
escape2me
Apr 20, 2004 12:49 PM
Johnny Blaze
Jul 26, 2002 09:16 PM
