how much hp should i expect d16a6??
How much hp should I expect from a d16a6 boosted..using precision sc34 turbo, sfp manifold, 28x9x3 fmic, 2.50" dp flared to 3", 3" piping all the way to universal apexi turbo muffler using 450cc injectors, and uberdata?? all this is going into a 1991 honda crx hf.
Modified by skellator_thoj at 2:42 AM 2/20/2004
Modified by skellator_thoj at 2:55 AM 2/20/2004
Re: how much hp should i expect d16a6?? (skellator_thoj)
Without a decent EMS i would say around the 175-185whp range on 9-10psi... that's assuming you ditch that overkill of an intercooler.
Re: how much hp should i expect d16a6?? (lazerus)
A typical D series on 10psi of boost with hondata and larger injectors will peak out around 190-200whp. 200 is getting lucky though.
Because he is not running a decent EMS he will not be able to fine tune to get those extra 10ish horses.
And as I said before, he will have even less power if he uses that gigantic intercooler on the set-up. Pressure drop is a bitch.
Re: how much hp should i expect d16a6?? (PrecisionH23a)
Uh, this is D16A6, the headflow is much better than the typical SOHC VTEC. I'd b inclined the think a good tuned D16A6 @ 10 psi would put out in the 230 whp range.
Re: how much hp should i expect d16a6?? (J. Davis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J. Davis »</TD></TR><TR><TD CLASS="quote">175-185 whp, yeah, but what about the 700whp to the spare tire?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J. Davis »</TD></TR><TR><TD CLASS="quote">Uh, this is D16A6, the headflow is much better than the typical SOHC VTEC. I'd b inclined the think a good tuned D16A6 @ 10 psi would put out in the 230 whp range.</TD></TR></TABLE>
So why did you agree with me earlier about 175-185 then all of a sudden change your mind? I guess you overlooked it was an A6 too huh.
I am not a sohc expert, but I would find it hard to believe the head is going to make a 60whp increase.
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrecisionH23a »</TD></TR><TR><TD CLASS="quote">A typical D series on 10psi of boost with hondata and larger injectors will peak out around 190-200whp. 200 is getting lucky though.
And as I said before, he will have even less power if he uses that gigantic intercooler on the set-up. Pressure drop is a bitch.</TD></TR></TABLE>
a decent ems? he has complete control over his fueling and ignition maps, what else do you really need for a 200whp sohc?
BTW: i think someone on here just made 216whp @10psi on a d- series with uberdata..
Re: how much hp should i expect d16a6?? (Mpir3)
You are correct... forgive me for overlooking the uberdata. My mind was not functioning correctly at 5am last night, lol.
What would be the number for a d16y8 (stock internals) w/ a garrett t28. Also much psi can I go w/o blowing the internal
Re: how much hp should i expect d16a6?? (Dasani)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dasani »</TD></TR><TR><TD CLASS="quote">What would be the number for a d16y8 (stock internals) w/ a garrett t28. Also much psi can I go w/o blowing the internal</TD></TR></TABLE> with good engine management, proper A/F, correct plugs, and good intercooler, i would say 160 at 7 or 8 psi. i would go no higher with stock internals.
Re: how much hp should i expect d16a6?? (snoochtodanooch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by snoochtodanooch »</TD></TR><TR><TD CLASS="quote"> with good engine management, proper A/F, correct plugs, and good intercooler, i would say 160 at 7 or 8 psi. i would go no higher with stock internals. </TD></TR></TABLE>
I am actuall a little more familiar with the Y's then the A's. A few members on this board have pushed their Y's to 11-12psi. A common whp to expect at 10psi is around 170-180 without a decent ems. With an ems, youll be in the 190's.
Re: (dctoast)
I have a similar sort of setup check the link in my sig if you wish. But really you should search, question had been asked and answered many times..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J. Davis »</TD></TR><TR><TD CLASS="quote">Uh, this is D16A6, the headflow is much better than the typical SOHC VTEC. I'd b inclined the think a good tuned D16A6 @ 10 psi would put out in the 230 whp range.</TD></TR></TABLE> Yeah I doubt you would see those numbers will uberdata. 200whp is typical.
jinxproof99
01-26-2004 02:59 PM
10psi, boost, charleston, d16a6, horsepower, hp, internally, make, moddiefied, psi, sale, soch, stock, t28, wheels
