size of intercoolers...make a difference?
Old Feb 6, 2006 | 05:06 PM
got_boost16's Avatar
Default size of intercoolers...make a difference?
ok, if i have a intercooler that's good up to 350 hp, let's say a precision intercooler, if i upgrade to a bigger one that can hold up to 600 hp, will i get more hp out of the bigger one....sorry i'm dumb
Old Feb 6, 2006 | 05:14 PM
quik sol's Avatar
no, you will lose hp.
Get a intercooler thats a little higher than how much power your going to put out.
Bigger intercooler = bigger pressure drop, which means you will have to run more psi to hit a hp goal.
Old Feb 6, 2006 | 05:15 PM
Default Re: (quik sol)
anyone else agree
Old Feb 6, 2006 | 05:28 PM
vtecspeed1320's Avatar
Shooting Star
if your gonna run 350 hp there is no reason to get a 600hp intercooler unless someday you plan on pushing that...
Old Feb 6, 2006 | 05:34 PM
Default Re: (vtecspeed1320)
so what kind of intercooler do u suggest, i heard precision for the money is tight
Old Feb 9, 2006 | 05:51 PM
eightvalver's Avatar
Default Re: (got_boost16)
i would like to know this as well,
why dont you just turn up the boost...
and when you do turn up the boost doesnt more surface area from the bigger intercooler decrease temps more?
Old Feb 9, 2006 | 08:42 PM
Silverbullet86's Avatar
in response to the negative replies:
No, you will not loose HP. Your pressure will drop, but that means nothing because you've increased the volume. It's still the same mass of air going into the motor. If anything, you may gain HP from the colder temp. The only disadvantages you will have is more turbo lag. The big 24x12x3" FMICs that you see on 240s are tipically rated 500+ HP. How many of them push that much power? very very few. Most r running a stock SR20 with bolt ons (240whp/ 280bhp at most). Those FMICs are 30HP increase at top end, no joke lol. Bigger= better.
Old Feb 9, 2006 | 08:50 PM
tony1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quik sol &raquo;</TD></TR><TR><TD CLASS="quote">no, you will lose hp.
That's a common misconception, but it's entirely wrong. A smaller ic will have more pressure drop because you're trying to cram more air through a small hole, creating a restriction, which results in more pressure at the inlet than at the outlet, which is "pressure drop".
Old Feb 9, 2006 | 09:16 PM
redzcstandardhatch's Avatar
something different
Default Re: (tony1)
what about an absolutely enormous intercooler?
Old Feb 9, 2006 | 10:37 PM
tony1's Avatar
Default Re: (redzcstandardhatch)
Like the size of a football field? Who cares?
Old Feb 9, 2006 | 11:47 PM
djnikko's Avatar
Default Re: (tony1)
Is there a formulae or conversion chart somewhere to work out HP/CC/PSI vs intercooler sizing, basically a guide to help you choose the right intercooler for your setup.
Thanks
Old Feb 10, 2006 | 12:22 AM
EnzoSpeed's Avatar
Default Re: (djnikko)
Intercoolers are already rated by hp. What else could you want?
Old Feb 10, 2006 | 01:34 AM
quik sol's Avatar
oo, I stand corrected. ya learn something new everyday.
Old Feb 10, 2006 | 10:33 AM
booja's Avatar
all i know is, every person i see that upgrade their IC... like me... gain power from it... ive never seen hp loss from upgrading
unless theres a leak in it or something or its poorly made and designed
Old Feb 10, 2006 | 10:42 AM
andysila's Avatar
so what could be noticed if you have a 350 whp on a 600 hp intercooler? yes i know pressure drop, but does pressure drop= lag?
Old Feb 10, 2006 | 12:25 PM
turboedc2's Avatar
Default Re: (andysila)
i just got my precision intercooler 750hp anyone using the 825hp one...is it worth the money 100 dollars more for 3 inches would it make that big of a diffrence...
Old Feb 10, 2006 | 03:54 PM
andysila- read my previous response. i covered it all.
by using a larger intercooler, there is more volume/area. You now need to fill that volume because pressure is the same throughout the whole system. So yes, more turbo lag, but totally worth it.
Old Feb 10, 2006 | 05:37 PM
TurboTeG4's Avatar
Default Re: (Silverbullet86)
I changed my drag intercooler to the large pwr ones that earl has, I have not noticed Any decrease in power and im only makin 300whp. If anything I think I gained power cause now my tires squeal a lot more, more cold air , a lot more cold air.
traxxasx
Aug 20, 2011 11:15 PM
turbodan4
Mar 25, 2006 03:31 PM
Honda-Pilot
Apr 21, 2005 08:41 PM
prelude122
Jul 28, 2004 09:07 PM
HaRrYbOy
May 3, 2004 02:27 PM
